64 windshield
Old Jul 29, 2002 | 04:38 PM
berkad's Avatar
berkad
64 windshield
Old Jul 29, 2002 | 10:16 PM
64y292's Avatar
64y292
64 windshield
will a windshiled from a 66 f700 fit in a 64 f100, it looks like its the same glass to me?
Old Jul 30, 2002 | 07:00 AM
William's Avatar
William
64 windshield
Yes! Replace the rubber gasket, put the gasket on the glass, put the stainless on the gasket, install. Have some soapy water (lots of it) and a helper handy. Use a heavy cord to slip the gasket over the body seam and install. When your finished use some butyl rubber sealer between the gasket and body and in the lower corners of the gasket, between the glass and gasket. Clean up the mess with alchol and a single edge razor blade. I have found that it is a good idea to put all screw drivers and other metal prying devices in a locked tool box and put the key where you cant find it. Wooden wedges with the sharp edge trimmed off, (shims), work well for those times when you just must pry on the gasket. Good luck.
William in Atlanta
Old Jul 31, 2002 | 12:38 AM
leonharu's Avatar
leonharu
64 windshield
61-66 ARE THE SAME.YOU CAN GET A TINTED ONE AT CAROLINA CLASSICS AND LMC I THINK,IF YOU NEED A NEW ONE.
RUSTY
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
