Weird clunk
Old Mar 21, 2021 | 09:40 PM
muddslinger48's Avatar
muddslinger48
Weird clunk
I have a 2000 f250 zf6. I am getting a weird clunk or jerk that you can fell under heavy throttle taking off from a stop. If I accelerate under real light throttle I do not fell it. Anything over say 50% throttle seems to do it. I have replaced the whole drive line with spider joints and it still does it. It’s nothing audible, I can just fell it threw the seat. Any ideas where to look next?
Old Mar 21, 2021 | 09:59 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
First thought is bad end links on the front sway bar.
Old Mar 21, 2021 | 10:40 PM
BWST's Avatar
BWST
Got Data?
Do you have a CCLB with the 2 piece driveline? Could it be carrier bearing movement?
Old Mar 22, 2021 | 10:45 AM
lpzd's Avatar
lpzd
did you grease the splines on the slip section of the drive shaft?
i used to have a definite thud on take-off pulled apart drive shaft put some good grease into the female section reassembled thud gone.
Old Mar 22, 2021 | 12:44 PM
Paul_R7.3's Avatar
Paul_R7.3
That was my first thought too
Old Mar 22, 2021 | 08:32 PM
bigb56's Avatar
bigb56
I'll third the splines on the slip joint, very common on our trucks. The original splines were teflon coated which by now has worn off. Ford sells a special teflon grease to put in there. Some of us (me) have added a grease zerk so it can be greased without disassembly.
Note in the pics I ground an opening all the way around the splines to let the grease find it's way around. The groove does not go all the way to the shaft so as not to weaken it.
Old Mar 23, 2021 | 01:55 AM
aawlberninf350
It's a Van Gogh
I thought that is a 4R100 deal and not a ZF6 deal.
Old Mar 23, 2021 | 08:26 AM
lpzd's Avatar
lpzd
same drive shaft 4r or ZF
Old Mar 23, 2021 | 09:12 PM
muddslinger48
So y’all recommend me putting some Ford Teflon grease in the female section of the slip joint?
Old Mar 23, 2021 | 11:31 PM
aawlberninf350
It's a Van Gogh
Good plan!
I was lucky, there was still existing grease I could smoosh back into places of contact. IIRC most of it was on the male side. But much better to be armed with the right lube and do it right.
Old Mar 24, 2021 | 08:33 AM
bigb56's Avatar
bigb56
Yes. Don't try to force too much in there or you'll get an air lock when you try and push the splined shaft back in.
Old Mar 24, 2021 | 11:51 AM
AllaboutMPG's Avatar
AllaboutMPG
mark both parts of the shaft before you take it apart so it goes back together in the same alignment.
Zeropowerstroke99
Jun 24, 2016 05:55 AM
Ironoutlaw2010
2004 - 2008 F150
Jul 28, 2015 08:32 PM
KSman889
1997 - 2003 F150
Dec 16, 2014 05:57 PM
Banjobanger
6.7L Power Stroke Diesel
13
Jul 6, 2014 10:06 PM
97biostroke
Jul 4, 2010 12:39 PM
