Sponsored by: Auxito
Front end knocking
Old Dec 12, 2014 | 08:16 PM
KSman889's Avatar
KSman889
Front end knocking
I have a 2002 F150 Lariat with just barely over 100K. Recently when I reverse and then shift it into Drive and go forward there is a clunk sound coming from the front end passenger side I believe, it's worse and louder when I turn. There is also always a high pitched squeak as I drive coming from that side as well.
The CV boot has a tear in it and there is grease flung all over the wheel well. Could it be the CV joint is going bad or maybe a bearing? Hopefully nothing to do with the transmission.
Old Dec 14, 2014 | 05:42 PM
ekg_80's Avatar
ekg_80
It sounds like you need new CV joint. That grease that came out of the tear is there for a reason.
Old Dec 15, 2014 | 05:39 AM
KSman889's Avatar
KSman889
That's what I was afraid of.
Old Dec 16, 2014 | 05:57 PM
Spotty's Avatar
Spotty
Yeah...it should not be ripped, but make sure the sway bar links on both ends are not broken. They are cheap and easy to do if so. The sway bar bangs around when one is broke.
Ironoutlaw2010
2004 - 2008 F150
Jul 28, 2015 08:32 PM
378wby
Dec 7, 2013 02:30 PM
John7894
Dec 21, 2011 04:14 PM
rb8484
Feb 7, 2009 09:28 AM
gagnonconsulting
Jan 8, 2006 10:09 PM
