Engine problems :(
Old Mar 20, 2021 | 04:31 PM
Tclemens2's Avatar
Tclemens2
Engine problems :(
1973 f100 360 2wd
Hey guys, so I had and exhaust leak because some bolts were missing. I replaced the bolts and gasket and now its smoking a lot near the section were the manifold meets the exhaust pipe (it’s the quarter size manifold). Does this mean it’s not torqued down all the way? Also does anyone have an pictures of what the fuel lines should look like at the back of the truck where the metal gas line meets the tube line which goes to the sending unit? I think I set it up right but I’m not sure. Feel free to ask me questions about these problems, I might have explained them wrong 😅
-Travis
Old Mar 20, 2021 | 04:42 PM
redroad's Avatar
redroad
Possible valve cover oil leak into where the exhaust manifold meets the head. Check here for the answer to your other question on diagram.
Old Mar 20, 2021 | 06:07 PM
jakeharp's Avatar
jakeharp
X2 on the valve covers leaking, thats the sure sign of an FE motor... poke your head up under the wheel wells and shine some light on the rear of the head where the covers sit and look for oil creeping down the head and block onto your exhaust. If so wipe good run the truck and confirm. Then you get to pull the valve covers and practice witch craft trying to get them to seal, just did this today on my passenger side....
F-250 WARHORSE
Feb 18, 2012 06:37 PM
tjcnok
Aug 18, 2007 06:01 AM
mfriesen
1983 - 2012 Ranger & B-Series
Jul 8, 2006 09:04 AM
jseim44
Jan 10, 2006 09:11 PM
laswalker
May 16, 2004 07:14 AM
