360 exhaust problems!
Old May 15, 2004 | 08:00 PM
laswalker's Avatar
laswalker
I'm in need of some help with my exhaust manifold. I need the studs that hold the donut seals an flanges for the exhaust pipes to the manifold. Everywhere I go they have the seals but no studs. Does anyone know where I might get some at. Any help would be appreciated.
Old May 15, 2004 | 11:46 PM
fordloverf2501970's Avatar
fordloverf2501970
i drilled mine out and tapped them. 8 grade bolts now never comes loose and no more leaks. that is if your talking about those rusty forever breaking off studs that attach the pipes to the manifold. i would suggest taking them off for this project and also replace the exhaust studs with new 8 grade bolts and run a tap thru the threads to clean out that rust, double gasket it and spray that copper sealing spray a well, got my engine so quiet i could hear the exhaust valves leaking air, which in turn got me involved in where i am at now rebuilding the engine into a 390 bored 60 over. good luck
Old May 16, 2004 | 05:48 AM
rebocardo's Avatar
rebocardo
I agree, if yours are broken I would go with 5/16 - 3/8 coarse bolts and drill out the studs. As long as you know the rough size for both ends, you can order generic studs from NAPA.
Old May 16, 2004 | 07:14 AM
laswalker's Avatar
laswalker
The studs haven't broken yet. I replaced the seals last summer. I got the studs to break loose instead of the nuts. But when I tightened them back down. They just never where tight enough. Started leaking again. Maybe I will try to take the manifold's off.
