No instruments, won't shut off
Old Mar 20, 2021 | 03:50 PM
Chad LaChapelle's Avatar
Chad LaChapelle
99 f350... no instruments and will not turn off by key... have to pull fuse to stop..
Have swapped out GEM and ignition and no change. Any ideas?
Old Mar 20, 2021 | 06:15 PM
dn29626's Avatar
dn29626
Pulling that fuse is the kill.
Old Mar 21, 2021 | 04:36 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Fuse 16 should be Trailer battery charge on your model year, not related to your issue.
Which fuse did you pull to kill the engine?
Old Mar 21, 2021 | 06:04 AM
Chad LaChapelle
My mistake, fuse 16 in cabin says instruments but apparently only gets power when high beam on.. i pulled a large fuse in engine bay for the idm to kill engine. Cannot remember the number (26 or 27 ) as have done it so many times now.. have been chasing this issue for a long time... simply hoping for new ideas
Old Mar 24, 2021 | 03:45 PM
Chad LaChapelle
Anyone have any ideas ?
Old Mar 25, 2021 | 12:23 AM
aawlberninf350
It's a Van Gogh
Fuse 29 (5A) is also instrument cluster, replace that and see if it helps.
Diagrams below.
Still stumped on the not turning off issue.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 25, 2021 | 08:00 AM
SkySkiJason's Avatar
SkySkiJason
Check ignition switch on steering column.
Not turning off means something is staying hot/12v that should not be. In the pin outs for switch, you’ll find wires that are only supposed to be hot with ignition switch turned to ON/RUN. We use one of these for ‘after run’ for turbo timer and ‘purge cycle’ for vegetable oil conversions.
Have you removed cluster to see if it’s plugged in good?
Old Mar 25, 2021 | 08:25 AM
FordTruckNoob's Avatar
FordTruckNoob
Check your grounds. Weird fuses getting pulled to stop an engine sounds like power is getting backfed through circuits.
Old Mar 26, 2021 | 02:09 AM
Chad LaChapelle
am pulling big fuse 27 for.idm in engine bay to kill engine. Otherwise 30 in cabin kills it too. all fuses are good and never blowm ever. This.all.just started happening all of a sudden...
lostislandguy
15
Mar 8, 2023 01:04 PM
Kalslade3
Dec 12, 2020 03:16 PM
Waterwise
Jul 18, 2017 12:40 AM
imper
Nov 21, 2010 03:14 PM
the85gti
6.4L Power Stroke Diesel
Sep 5, 2009 10:56 AM
