Need some help from those of you who have been inside the 6R140. I have a 2012 F350 6.7L 4WD. I ordered the SPE valve body and during the install, it states I have 2 seals that connect the clutch tubes underneath the transmission. When I pulled it apart, I only see 1. I know it did not fall off. Can anyone shed some light if they know for a fact how many there need to be? Pics are included. Thanks in advance
Looking at the pictures there are witness marks that indicate there was a seal installed. You need to find it or replace both of them. Replacing them is the preferred choice.
