Engine ?
Old Mar 19, 2021 | 01:56 PM
Dominic Morrison's Avatar
Dominic Morrison
Engine ?
So I have this hose can someone identify and explain pls and thank you.i
Old Mar 19, 2021 | 02:09 PM
Franklin2's Avatar
Franklin2
That large fat hose with the ridges in it? That is the hot air hose that went to the original aircleaner. The original aircleaner had a metal tube with a air valve in it, and then a hose that went over to the radiator support. There was a sensor in the aircleaner that sensed the temp of the air. It controlled the air valve and that drew hot air through that hose and mixed it with the cold air from the radiator support hose and fed it into the aircleaner. This makes the engine run better in extreme cold and extreme hot weather.
Old Mar 19, 2021 | 02:25 PM
Dominic Morrison
Dumb question what should I do with it lol.
Old Mar 19, 2021 | 02:35 PM
Max Capacity's Avatar
Max Capacity
remove it. Unless you plan to reinstall the OEM air cleaner,
Old Mar 19, 2021 | 02:39 PM
Dominic Morrison
Does it need to be capped?
Old Mar 19, 2021 | 02:42 PM
Max Capacity
I'm sure one of the purest will say different...but us old guys from the 1970's removed that from are cars when we put a different air cleaner on like you have. I never plugged that opening on the manifold heat shield. Then when I put headers on...
Old Mar 19, 2021 | 02:46 PM
Dominic Morrison
I appreciate the help!
Old Mar 19, 2021 | 05:05 PM
Rusty_S's Avatar
Rusty_S
No need to plug it. The purpose is for the aircleaner to pull air up around the exhaust manifold when cold to help warm the engine up as well as to help prevent carb icing.
I thought of installing it on the 306 I am building with shorty headers as I am partially concerned of icing on my 800cfm Sniper Stealth EFI.
Old Mar 19, 2021 | 06:42 PM
Franklin2's Avatar
Franklin2
I would say save it, but you can get those hoses in the store. I see you live in Colorado. If you drive it in the winter you may be hooking all that back up.
Old Mar 19, 2021 | 09:19 PM
Dominic Morrison
Thank you appreciate that!
4drocket
Jan 15, 2021 12:53 PM
Craigsbackyardrepaircentre
Jan 5, 2021 06:21 AM
KrenzyRyan
62
Dec 20, 2013 10:04 PM
Gregruk
80
Mar 28, 2012 05:08 PM
DasCheckers
15
Feb 5, 2008 11:06 PM
