Taillights
Old Mar 19, 2021 | 09:21 PM
Dominic Morrison's Avatar
Dominic Morrison
Taillights
Guys I'm looking for aftermarket taillights. Any suggestions thanks, also can 89 f150 taillights fit a 1982?
Old Mar 20, 2021 | 03:23 AM
dagwood57107's Avatar
dagwood57107
Pretty much interchange from 1980 to 1996 but I'd read what others have to say about it.
Someone talks about interchange compatibility here: https://www.ford-trucks.com/forums/5...aillights.html
I will also state that if you end up going with LED's, you may (and probably will) have issues with your blinkers not working properly. You can read more about that here: https://www.ford-trucks.com/forums/1...ed-lights.html
Old Mar 20, 2021 | 06:04 AM
FuzzFace2's Avatar
FuzzFace2
I am guessing we are talking style side tail lights and not flare side lights?
If flare side you have to go after market as that is the only light that is the same size / shape / bolts up as the factory lights did.
You will need to do something with the plug as it will be different from what is on the truck.
I was lucky and had both sides of the plugs but had to make my flare side tail light harness from my style side parts truck harness.
Dave ----
FORDF250HDXLT
General Automotive Discussion
Jan 25, 2020 10:28 AM
Connecticut Calvin
Jan 24, 2016 06:29 PM
48' fordster
Jul 5, 2009 07:19 AM
Franken-Truck
Virginia Chapter
Oct 23, 2005 11:17 PM
