Hard first shift
Old Mar 16, 2021 | 07:59 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Hard first shift
Anyone notice a hard transmission shift, the first one only after starting off on a very cold day? Seems to need time to wake up in the morning and is fine once warmed up. I usually remote start it and it runs about 5 min before departure. Normal?
Old Mar 16, 2021 | 09:57 PM
Bluegrass 7's Avatar
Bluegrass 7
Could you accept the fact the transmission fluid viscosity is higher when cold?
Look at the trans temps on the dash to see this and track it's rise.
Good luck.
Old Mar 16, 2021 | 10:15 PM
ford390gashog's Avatar
ford390gashog
The hard shift is from first to third, it's way more pronounced if you don't just throttle through it. You will also notice cold it will hang in seventh gear. This is all to bring the catalyst up to temperature quickly. The 10R140 has a electric pan heater for the fluid and booster pump, the ULV pours below -20. This isn't for the transmission it is an attempt at getting the engine to temp as fast as possible. This programming is carried over into the 2018-2020 trucks with the 6R80 and SSV. It was not found on the 2018 3.3 trucks.
Old Mar 17, 2021 | 06:54 AM
SpencerPJ's Avatar
SpencerPJ
Yes, I have noticed quirky things as you suggest. I also have come to peace to give myself a chance to learn and accept my new truck, and it acts differently than my last truck, it has never failed me, or been back to the dealer for that matter. Enjoy your truck sir, turn off the gear indicator and drive it. If it breaks, it's under warranty.
Old Mar 17, 2021 | 10:20 AM
MCDavis's Avatar
MCDavis
The last vehicle that didn't shift wonky when cold was my '99 302V8 Explorer.
The current 2020 shifts OK cold in my opinion. The wife's '17 MDX slams gears/shifts until warm. It's unnerving but you get used to it.
In short...it's standard op! Drive it!
Old Mar 17, 2021 | 08:04 PM
KJ Smith's Avatar
KJ Smith
It gets better over time.....
I'm ~105k and the truck runs, drives and shifts better now than it did new.
mkb1314
2009 - 2014 F150
Jul 5, 2023 03:27 PM
happylogan1
2009 - 2014 F150
Mar 13, 2020 04:59 PM
FTrookie
2009 - 2014 F150
16
Mar 7, 2010 06:57 PM
cowmilker08
Feb 17, 2010 05:39 AM
1967fordranger
Jan 24, 2002 10:43 PM
