Cold shift Schedule always
Old Feb 14, 2010 | 02:01 PM
cowmilker08's Avatar
cowmilker08
My truck always starts and goes into cold shift mode, even if I start 2 minutes after I shut it off and its still warm enough for the needle to be on the O in normal.
So why does it do this?
Old Feb 14, 2010 | 02:21 PM
DRRXR's Avatar
DRRXR
DUNNO BUMP
Old Feb 14, 2010 | 03:49 PM
joe_13894's Avatar
joe_13894
The shifts are based on transmission oil temp. There is a thermistor in the solenoid pack to measure it.
You can see the pinout here:
1996 Bronco/F-Series
Unfortunately I don't know what the resistance should be.
Old Feb 15, 2010 | 08:17 AM
Action4478's Avatar
Action4478
I worked on a fix for the cold shift , But I only have it when its below 70 degrees out side . It can be removed with programming, or by adding a resister ..
Old Feb 15, 2010 | 09:56 AM
DRRXR's Avatar
DRRXR
Temp Sensor
https://www.ford-trucks.com/forums/a...ictureid=26727
Old Feb 15, 2010 | 02:12 PM
cowmilker08
I don't want to get rid of it, but I don't think it is necessary that it goes into cold shift every time I start the truck. I mean I could drive 100 miles, shut the truck off for 10 seconds, restart it and it would be in cold shift mode.
I couldn't make heads or tails out of those two links.
What pins should I check the resistance across?
Old Feb 17, 2010 | 05:39 AM
DRRXR's Avatar
DRRXR
link I added
In the link I added on the left side of the diagram list that the pcm monitors the voltage drop across the temperature sensor next to the coast clutch solenoid. Perhaps there is a conductivity issue in the pins or the wire or the sensor is bad. Keeping your truck in the cold shift mode.
See page 3 the TST is about the size of a pin cap. It should come out a a 1/4 turn. There will be a qt or so of fluid behind it.
http://www.artcarr.com/merchandise/t...al/18/265.acpp
