sliding yoke removal
Old Mar 16, 2021 | 07:44 PM
dantimdad's Avatar
dantimdad
I am replacing the U joints and the support bearing on my 77 f150 2WD.
I can move the sliding yoke to these extremes and no further:
How do I remove it so I can replace the support bearing. It's like it hits a hard stop in the extended position.
I don't see a clip or anything holding it on.
Appreciate your help.
Old Mar 16, 2021 | 08:43 PM
redroad's Avatar
redroad
The threaded cup at the end has to be loosened from the male threaded part. A pipe wrench works taking care not to bugger it up. Grease build up that has hardened on the inside is usually preventing it from moving. Brake clean can help soften that build up too.
Old Mar 16, 2021 | 08:46 PM
dantimdad's Avatar
dantimdad
Thanks! I actually picked up a pipe wrench and said “nope I don’t want to booger this up. I better ask first”
Old Mar 16, 2021 | 09:18 PM
redroad's Avatar
redroad
Did you try a couple wraps of electrical tape. Water pump pliers?
Old Mar 16, 2021 | 11:04 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The d/s end splines are catching on the lip/seal that is in the end of the threaded on end cap. X2 carefully loosen it (just be careful to not squeeze it to hard), it is fairly thin metal. Elec/duct tape protection. Large Channel locks (adjustable pliers) with light squeeze pressure and steady pressure in the loosening direction and a rap/tap with a rubber mallet. Yes spray brake cleaner or worse case maybe a VERY LITTLE propane torch heat on the cap to loosen up the gunk. Once its loose thread it off and then it should slide apart. FYI they are fine threads on the assembly. Worse case just go to town and just yank it apart. Probably a good way to tear the seal and I believe the seal is built in the end cap? Aviation cannon plug (electrical plug) pliers have rubber over laid jaws with great gripping power.
Old Mar 17, 2021 | 07:33 AM
dantimdad's Avatar
dantimdad
I am going to put duct tape on a pipe wrench when I get home from work today and give it a go.
I appreciate all the input!
I have valvoline cerulean grease with a 500 degree drop temp that I used on my bearings, I suppose that will do for this as well?
Amazon Amazon
nashvegas99
Aug 9, 2020 10:09 PM
beanhead6D5
91
Oct 28, 2019 07:12 AM
XSoph
30
Apr 28, 2018 09:44 PM
Monana ford Man
Aug 19, 2014 01:10 PM
dunecj2a
Dec 20, 2012 12:05 AM
