Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Drive Shaft Reviews
Reviews and comparisons of top products
94 f350 4wd rear driveshaft carrier bearing removal
Can anyone please tell me the easiest way to remove the driveshaft carrier bearing. I need to replace mine and while I am having the tranny done I figured its a perfect time. I have the driveshaft removed. I was hoping there was a way to remove the bearing without having to remove the u joints...thanks.
I started by marking the driveline with a hammer and punch.This way I would have it in the right position when reassembled.
<TABLE id=ncode_imageresizer_warning_5 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE> <TABLE id=ncode_imageresizer_warning_8 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
After I had removed the driveline I remove the nut that holds the carrier bearing in place.
<TABLE id=ncode_imageresizer_warning_3 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
A impact and 1 5/16" socket and prybar did the trick.Make sure you mark witch way the yoke slipes on the splines.
Then the fun begins!I remove the metal housing from the rubber and cut it off with a knive.
<TABLE id=ncode_imageresizer_warning_2 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE> <TABLE id=ncode_imageresizer_warning_7 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
With a little help from a cutting torch the bearing was off the shaft.
<TABLE id=ncode_imageresizer_warning_4 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
I warmed the metal guard and it droped right into place with a tap from a hammer.
<TABLE id=ncode_imageresizer_warning_1 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
I set the bearing into place,then used the old bearing to drive it onto the shaft.
I used some thread lock on the nut and thigten the $#@* out of it with my impact.
<TABLE id=ncode_imageresizer_warning_6 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
Then I reassemabled from there.
I also used thread lock on the u-joint bolts also.I don't like drivline bolts coming out.
Not to bad of a job to do.Took about two hours,and no more virbration. <!-- / message -->
XSoph
30
04-28-2018 09:44 PM
smokersteve
01-23-2013 10:55 PM
ROBBINthaHOOD
08-20-2012 07:17 PM
