Morryde X Factor...
Old Mar 16, 2021 | 03:58 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Morryde X Factor...
Since I don't have a welder or welding skills, I am looking at the Morryde X Factor cross member (or 3) for my 5th wheel. Because I have the Lippert Correct Track already installed, it appears I need Morryde MR69ZR for the Correct Track instead of the Morryde MR49ZR.
The installation instructions are identical, even though the kits are clearly different. The bars are the same, but the Correct Track version has much more hardware. I went to the Morryde website as well, but their web designer was high or a toddler when they built that site, so I resorted to searching Google images for the differences. I am unsure about where the plates circled in red in the image below go when installed. I am sure I can figure it out, but I prefer to learn from the experiences of others instead of learning the hard way myself.
In addition, if anyone has any thoughts on these things, by all means share them here. I think I can get all 3 spring hangers based on the plumbing under the trailer, but I am 100% sure I can get 2.
I read on an RV forum in a post from 2014 that Morryde (at the time) would build a non-adjustable kit for a customer if the axle code and measurements were provided. I may go this route too if I am confident there is value in the kit.
Thanks for any advice or thoughts you have, I do appreciate it.
EDIT: Upon further inspection and going out to have a second look, the front and rear hangers have the Correct Track pucks where the middle hanger does not. So, the middle hanger with the equalizer would need the Morryde MR49ZR instead of the other kit. I also verified that I am 99% sure the front hanger would NOT be able to have a crossmember installed due to the gray tank drain. I will attempt to fit a crossmember in there once I purchase a kit for the middle hanger to verify this fitment issue.
Again, any thoughts or opinions are welcome.
Old Mar 17, 2021 | 05:32 PM
Sous's Avatar
Sous
FTE Emeritus
Well, a friend of mine in TX saw this thread and offered to weld up some steel for me when we come by on our upcoming cross country trip. So, I am leaning toward that method for several reasons to include $75 vs $400, specialized custom fitting and being able to box in the hangers at the same time via an experienced welder.
If anyone has Morryde X Factor and has a thought on their installation or feasibility I would still welcome the post. Just because I am no longer considering these as a viable option, does not mean someone else in the future would not find this thread useful.
Have a nice camping season everyone!
Old Mar 21, 2021 | 11:57 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Good move getting the same solution only better!
My opinion: I would do this at all hanger pairs on a given trailer. The reason I say this is: The pair that is not done will be the weaker pair, and will be enjoying the extra stress that can be sent that way by the stronger pair(s).
Old May 7, 2021 | 07:55 AM
Sous's Avatar
Sous
FTE Emeritus
I ended up going with the bolt on kits from Morryde instead of the weld on via a friend. The timing and scheduling just was not working out well for him to help us out. I installed a X-Factor cross member on each of the 3 spring hangers. The install went very well with little to no confusion involved. I will say loosely install the larger bar and then bring the smaller one up to fit inside the larger one. An impact gun/wrench will do wonders for you during this install as well.
We towed the 5th wheel to a campground 30 minutes away and then back home yesterday. I forgot to look at the trailer wheels in the mirror on the way out, but did remember on the way home and backing into the driveway.
I am pleased to report the spring hangers (wheels at least) were very well planted and the X-Factor seemed to do a good job. Of course there was still some scrubbing on one set of tires on the dual axle 5th wheel, but the wheels themselves were not tilting in or out like they were prior to the cross member install.
When parking the 5th wheel at the house, I back it into the driveway at a 45° angle, then straight for 50 yards or so then a 30° angle the opposite direction off the driveway, over the grass and into the gravel parking space. Again, the wheels seemed firmly planted and supported during the entire backing in session. I was keeping a good watch on them this go around.
It seems this was a worthwhile investment, costly, but it appears to be providing verifiable benefits already.
Old May 7, 2021 | 12:14 PM
HRTKD's Avatar
HRTKD
I have wet bolts in my suspension. The two zerk fittings for the center pivot point are already difficult to access. Does the Morryde X Factor made it even more difficult to access the zerk fittings?
Old May 7, 2021 | 01:56 PM
'65Ford's Avatar
'65Ford
I installed three of the Morryde MR49ZR 8 or 9 years ago and very glad I did...keeps the hangers straight and stopped uneven tire wear.
BTW, I can't remember what kind of nuts came with this kit. I installed greaseable bolts and heavier shackles at the same time which included what I believe are called "stover nuts" so I used those to prevent loosening. A couple of the factory installed nuts were working their way loose...yikes... Some form of lock washer might perform as well.
This kit does not affect access to grease points with the dexter ez flex equalizer that I installed at the same time. The kit does not affect access to any of the other greaseable suspension bolts either.
Old May 8, 2021 | 10:22 PM
Sous's Avatar
Sous
FTE Emeritus
Not that I can see. I put the zerk fittings for the wet bolts facing outboard. I also put caps on the zerk fittings to help keep them clean.
The X-Factor bars are very stout, but are 3 sided with the bottom open, not completely boxed. So, if you did have the zerk fittings facing inboard then you would still have access.
Old May 8, 2021 | 10:28 PM
Sous's Avatar
Sous
FTE Emeritus
I also installed the Morryde shackles and wet bolt kit at nearly the same time. The nuts that came with the wet bolt kit are locking nuts and are one time use. I had to buy 4 longer wet bolts due to my Correct Track hangers and buying the wrong wet bolt kit. Oh well, it happens.
Morryde got me sorted out and everything installed quite well.
Thank you for providing your thoughts on the cross members, especially since you have had them for long. At this time, I feel they were a good choice.
Reeder
Nov 29, 2020 08:09 PM
drdit92
All Things Towing
Jun 12, 2018 02:12 PM
2002exPSD
Oct 28, 2015 04:46 PM
Thumper19
19
Sep 22, 2014 04:47 AM
Breaker 1-9
Ford Truck Parts for Sale
Oct 7, 2012 07:11 AM
