Hey folks. Drove the truck all morning, went out after lunch no start. Have juice, trying to narrow the problem down.I can start it with a remote starter off the relay. So i'm thinking the actuator on the column. How much juice goes to the relay? I put a meter in line to the relay and get a slight half volt bump when I turn the key, but nothing when I turn to start. Sound like the actuator? Oh yeah, the rod to the actuator is moving.
Reason: add
you should get 12 Volts... the Current(Juice) depends on the resistive load of the solenoid coils and can only be measured inline not passive unless you have a DC clamp on ammeter.
could be stripped gear tooth or broke actuator ... could even be the switch is coming apart....
I was up inside with my hand. Not coming apart, but I can't see it. I put a meter inline from the red wire(ignition) to the post on the relay
. Clamped the leads on and turned the key. Got a blip then nothing when I turned the key all the way
Reason: add
quite welcome.... I'm just kinda used to many not knowing meter usage and sometimes I have ended up chasing ghosts trying to help when a meter was used improperly ...
I'm sure you can understand that
