Stock boost numbers
Old Mar 16, 2021 | 12:19 AM
wkf94025's Avatar
wkf94025
Stock boost numbers
Researching various forums, seems like plenty of PSD 7.3L owners see boost in the high teens and twenties. Highest I have seen on my nearly stock '97 F350 is 12psi, stomping on it on an uphill freeway onramp. No performance mods on the truck that I'm aware of. Is peak boost of ~12psi weak? If so, what are typical causes other than boost leaks? And when cruising around 65mph on level ground in overdrive, what boost psi should I see, not accelerating?
Old Mar 16, 2021 | 01:09 AM
Hit Man X's Avatar
Hit Man X
I see 14-15psi per my Edge Insight on stock tune. No IC. Pretty plain mods/durability ones. Plenums resealed, new boots, Comp 910s, etc.
'Tow' mode does 19-20, same mods.
Old Mar 16, 2021 | 10:23 AM
97-psd's Avatar
97-psd
Were you empty or towing? If empty, that is not bad, but you may have a few small leaks which are hurting you a little. May want to look around the up pipes for any soot. Soot is a sign of exhaust leaks, which hurt boost performance.
Old Mar 16, 2021 | 11:18 AM
wkf94025's Avatar
wkf94025
I was empty. Taking the snake cam under the hood for the first time today. I also have RiffRaff's bellowed up pipes in my shopping cart, with safety off on the Buy Now button. Tempting, based on many reports that it's only a matter of time for the OEMs, and the strong endorsement of the RiffRaff bellowed.
Old Mar 16, 2021 | 11:53 AM
Hit Man X's Avatar
Hit Man X
Oh. I see 3-4psi at cruise I recall on flat roads here in Texas going around 65-70mph. I turn around 2500rpm at 70mph.
I have those RR uppipes. Fit and work well.
Old Mar 16, 2021 | 08:04 PM
Conner Stevenson's Avatar
Conner Stevenson
If you feel you might have some boost leaks, you can use a boost leak detector. You can make one, or DieselSite makes a nice one but you pay about $70 for it if I remember correctly. Solid numbers for a truck with that kind of mileage. I’m sure there area few boots you can tighten up/replace and probably could replace up-pipes. But your numbers aren’t too bad.
Old Mar 17, 2021 | 09:15 AM
wkf94025's Avatar
wkf94025
Thanks Conner. See my new thread posted moments ago on exhaust leek detection. For boost leaks, obviously, the pressurized air + soapy water method will be employed. I DIY'd a PVC-based rig for boost leaks on my 911 Turbo. Pretty straightforward to repeat for the 4" beast. Agree there probably aren't any major boost leaks if I can get ~12psi punching it without trailer in tow. Still, when I see guys reporting 20+psi, I get boost envy.
Old Mar 17, 2021 | 10:40 AM
Hit Man X's Avatar
Hit Man X
Is your truck still equipped with the stock downpipe?
12psi...was that shifting at where ever the E4OD does at WOT? Say 3300.
Old Mar 17, 2021 | 12:28 PM
JayTheCPA's Avatar
JayTheCPA
Don't.
More boost is more heat. More heat is less power.
FWIW, on my SOB v8 diesel, OE was ~17 psi at max power. Folks thought mods which got 20 - 25 psi were awesome. For the same reported power, I got 14 psi and the enjoyment of a less stressed engine. Even put that vehicle on a dyno to back-up the numbers.
Point is, the whole thing is a balancing act and boost is just a number in the larger scheme.
Old Mar 18, 2021 | 01:10 PM
wkf94025's Avatar
wkf94025
I *believe* it is still stock up and down pipes, but have yet to locate the original or 2nd owner to get full history of the truck.
Re shifting, yes, pedal to the metal starting at about 5mph on a highway rump sloping uphill for the duration of the pull. So shifting whenever the PCM/E4OD decided it was time. I can log with Torque Pro if details are of interest.
Originally Posted by JayTheCPA
Don't.
Great perspective. I will chase leaks, not boost numbers.
TexaSaiga
Jul 12, 2018 05:29 AM
derek0525
13
Jan 19, 2016 03:57 PM
endobear
Mar 17, 2015 11:16 PM
baddad457
15
Jan 13, 2012 01:22 AM
scalezy3b811
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 21, 2004 01:54 PM
