No start issue
Old Mar 13, 2021 | 10:16 AM
Landscape Doctor's Avatar
Landscape Doctor
No start issue
So I finished my rebuild couple weeks ago,,, after long cranks a sputter it finally started and ran great.
After that I put in under my house shop where I have heat. After a week sitting, was a pita to start. After it started I ran it for about 1 hour. Ran great no smoke, smooth ect. Next day I went on vacation. Got back last night and today went to start it and will not start. No smoke coming out of tail pipe.
What should I start to look for?
Old Mar 13, 2021 | 12:24 PM
BuddyBarnes's Avatar
BuddyBarnes
If you have not taken it for a good drive it will still have air in it causing hard starts.
Old Mar 13, 2021 | 01:20 PM
Landscape Doctor
I am getting 45 psi at the fuel test point.
On 200 psi when I put a gauge on the icp port.
Old Mar 13, 2021 | 04:28 PM
Landscape Doctor
I have been looking at everything and still cranks no smoke or sputter no start.
I borrowed another gauge to be sure mine was ok. Still 150 psi oil pressure or so when cranking.
I had another good ipr I put in thinking it was the issue but no luck.
In the process now of removing the hpop, put in a rebuilt one about 2 years ago.
Is there a way to bench test a hpop?
Old Mar 13, 2021 | 07:09 PM
oldbird1965's Avatar
oldbird1965
It take's 500 psi to start. I don't know of a way to test a hpop. The PCM has to see the 500 psi before it will command the IDM to fire.
Old Mar 13, 2021 | 07:26 PM
Landscape Doctor
I am only getting 150 +/-, I think I have a bad hpop according to this chart.
Bought a rebuilt 2 years ago.
What is the best hpop out there?
Old Mar 13, 2021 | 09:36 PM
oldbird1965
I have an adrenaline from dieselsite. Before that was a T500 but some guys are talking about a new one but I can't think of the name. Its starts with a C.
Old Mar 13, 2021 | 09:48 PM
Landscape Doctor
Thank You Much
Old Mar 13, 2021 | 10:22 PM
MJ79's Avatar
MJ79
I also have an Adrenaline on my truck. The company Glen is thinking of is CNC fab. I have heard good things about their pumps also.
Old Mar 14, 2021 | 10:08 AM
Landscape Doctor
So I did some more trouble shooting this morning.
I reinstalled the hpop to do more testing.
I removed the crossover line.
I gauged each head. 150+/- psi.
I then removed the connection on the 2 hpop lines at the heads. I plugged one and gauged the other to test. Then swapped the gauge to the other side and tested. Both where at 150+/- psi. So this somewhat confirms a bad hpop.
Does the IPR need to be functioning properly to do this test or does it not matter?
Old Mar 14, 2021 | 10:54 AM
Hit Man X's Avatar
Hit Man X
Crap wire to IPR will keep it from starting too. Efuel or that mechanical nonsense?
I have an Adrenaline. Works fine for me. Seems CNC Fab makes a solid unit too.
Is the truck cranking fast enoigh?
Old Mar 14, 2021 | 11:03 AM
Landscape Doctor
I tested the wires going to the IPR,, they checked out ok.
Yes next winter EFuel.
Yes cranking is fast.
I am totally beside myself,,, very fustrated.
So does the IPR need to work for the hpop to produce pressure for testing purposes or it does not matter?
Old Mar 14, 2021 | 11:11 AM
Hit Man X's Avatar
Hit Man X
That I am unsure about.
Old Mar 14, 2021 | 11:44 AM
Landscape Doctor
Thanks Hit Man, hopefully someone knows that answer,,, would be a great help.
Old Mar 14, 2021 | 01:51 PM
oldbird1965
I'm unsure of the IPR also but it stands to reason that if its stuck (partially open a little) it will not allow the oil to get to the heads. It might be your problem.
