General Automotive Discussion
Navigator Low Beams Issue
Old Mar 12, 2021 | 10:19 PM
spyderdyne's Avatar
spyderdyne
3rd Gear
Question Navigator Low Beams Issue
I have a 1999 Navigator AWD and the low beam headlights do not get power. I have been at this for months now and have literally made ZERO progress, so maybe someone here can help me. Here is what we know thus far:
- lights/bulbs/etc. work just fine when plugged in to my 2002 Navigator
- No power on the Low-Beam pin at the light fixture on either side.
- No power at the fuse panel on interior fuse 26 or 28.
- Replaced the MFS on the steering column and no change.
- There are no low-beam relays on this model.
- Somebody here has the same issue, but nobody mentions the solution...
- Fuses are not blown, and replaced them anyway.
- Lincoln forums are pretty much useless, and instead of trying to help they just say "don't do that..."
Not really sure where to go from here now. I hear tell of a mythical DRL relay box hidden on the passenger side somewhere, and similar model year Expeditions seem to have a DRL diode under the dash on the drivers side that I could check out. Replacing the entire headlight switch is pretty expensive since they are so old now, but I might try that next since I cannot find any instructions on how to test them.
Shot in the dark. Maybe someone here knows something, but this is a crappy mystery and I may just have to get raked over the coals at a shop to have it diagnosed soon because I am running out of things to check and try.
Thanks!
Old Mar 13, 2021 | 05:17 AM
JWA's Avatar
JWA
Personally I'd find a factory EVTM and use that to point check the circuit for your issues. I found this quickly on eBay: 1999 Navigator EVTM
tractorboy924
2009 - 2014 F150
Feb 28, 2018 12:50 PM
Shane Forbes
Oct 23, 2016 07:14 AM
20Mike
Mar 11, 2015 02:04 PM
maples01
Sep 15, 2011 07:07 PM
cbpadget
1978 - 1996 Big Bronco
Jul 15, 2011 10:23 PM
