Headlights only work in high beams
Old Mar 13, 2021 | 07:05 AM
FuzzFace2's Avatar
FuzzFace2
I replaced the dimmer & head light switch as part of the rebuild.
About a year after the truck was on the road 1 head light went out, I used the ones that came with the truck.
I replaced the both at that time.
Tail lights are new, had none with truck, and replaced the front side markers. Even all the dash lights are new.
So I should be covered for a bit LOL
Dave. ----
Old Mar 13, 2021 | 10:04 AM
BigBlue2's Avatar
BigBlue2
Dave. ----
I also keep a supply of bulbs for everything else...brake turn signal, tail, back up lights, licence plate and fender bulbs too!
Old Mar 13, 2021 | 11:33 AM
BigBlue2's Avatar
BigBlue2
I just checked my parts shelf and I realize that I'm out of headlamps. It's been quite a while since I bought any, so looking at what available out there today I see many sealed beam options. I'm going to start a new thread for exploring headlamp replacements.
Old Mar 13, 2021 | 05:29 PM
Franklin2's Avatar
Franklin2
Originally Posted by dagwood57107
Well the upgrade does add some complexity but its not bad. If I can do it, anyone can do it. Not only will the harness upgrade make your halogen lights brighter, I consider it a safety upgrade as well. Stock, if your dimmer switch takes a crap on you, it could kill your headlights all together which to me equals bad. Because the only time you're going to know if that switch goes bad, is when you are using it lol. With the harness upgrade, the lights get power directly from battery through some relays so if the switch goes bad, you will still have headlights. Yes, relays can go bad too but there are two of them - one for brights and one for dim. So that's my 2 cents. With all that being said, I would NOT do the harness upgrade until you figure out the current problem first.
Do you have a diagram of one of these relay conversions? Not seeing how with the conversion and a bad dimmer switch, that the lights would still work.
Old Mar 14, 2021 | 09:51 AM
FuzzFace2's Avatar
FuzzFace2
I think Dagwood meant to say "head light switch".
It was common when driving down a dark road with high beams on and the head lights would go out!
The switch has a breaker built in and over time it gets weak. Now you put a heavy load on the switch with the high beams or a trailer and you were now in the dark.
When the breaker cooled off it would reset but when in the dark going 50+ MPH just a few seconds is a long time!
What the relay kit does is takes the load of the head lights, they pull the most load, off the switch as the load is now through the relays.
The switch is only used for turning on / off the relays and that is vary little load at this point.
Now if the dimmer goes bad like we think maybe what is up with the OP then nothing will bring the lights back on short of replacing the switch or jumping it out to get to safety to get a new dimmer switch.
Dave ----
robert1839
Sep 9, 2020 09:43 AM
moynihan1129
Aug 27, 2019 07:42 PM
Skydivelout
Jan 27, 2018 07:09 PM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
Dj300ford
Aerostar
Dec 13, 2003 02:17 AM
