PreCycle Injector Clatter/Buzzing
Old Mar 23, 2021 | 06:09 PM
  #31
FJ Jerry's Avatar
FJ Jerry
I would think if my Multimeter is only reading 6 volt that my FICM is more than likely the problem even though, I have 49 volts of FICM main power. Am I correct in thinking this?
Old Mar 23, 2021 | 06:25 PM
  #32
bismic's Avatar
bismic
I don't see where you ruled out a bad harness.
Old Mar 23, 2021 | 06:28 PM
  #33
FJ Jerry's Avatar
FJ Jerry
Sorry...I am not ruling out anything. Just asking what you guys think is the more likely scenario. What should I try first?
Old Mar 23, 2021 | 06:32 PM
  #34
bismic's Avatar
bismic
To be honest, the best way to test the harness (IMO anyway) is to put an electrical load on each wire feeding an injector, and then seeing what voltage drop you get. A lot of people feed 12V power to the FICM connector and then rig up a headlight to the other end of the wire and then watch the light and measure the voltage at the light.
Old Mar 23, 2021 | 07:25 PM
  #35
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Having your FICM tested would help save you money on throwing parts at the truck. The volt meter isn't going to help much.
Excursion Gary
Jan 6, 2015 09:13 PM
MONAVIERONJON
Nov 18, 2014 09:38 PM
Ford_250
Mar 18, 2011 06:49 AM
tobacco farmer
Apr 21, 2010 04:34 PM
