1996 f250 rear brakes
1996 ford f250 all new rear brakes including cylinders brake pedal spongy as it was with old brakes. The rear brakes will only engage if i rapidly pump the pedal 7-8 times. I bleed the system the front brakes work fine. Which would you go to next rabs valve or new master cylinder? Thinking if there were an issue with the master cylinder the front brakes would be acting up as well?
iapexl8r
07-22-2006 03:43 PM
ubermich
06-28-2004 11:42 PM
