1996 f250 rear brakes
Old 03-08-2021, 08:59 PM
WalonJ's Avatar
WalonJ
WalonJ is offline
1996 ford f250 all new rear brakes including cylinders brake pedal spongy as it was with old brakes. The rear brakes will only engage if i rapidly pump the pedal 7-8 times. I bleed the system the front brakes work fine. Which would you go to next rabs valve or new master cylinder? Thinking if there were an issue with the master cylinder the front brakes would be acting up as well?
Old 03-08-2021, 11:19 PM
westcoasting's Avatar
westcoasting
westcoasting is offline
Did you adjust the brakes after you installed them?
Old 03-09-2021, 08:42 AM
WalonJ's Avatar
WalonJ
WalonJ is offline
westcoasting
Yes I adjusted them funny thing is though adjustment screw is completely closed on both sides only way i can get drum on. Summed that up to made in china parts?
for46016
1978 - 1996 Big Bronco
04-01-2009 09:33 PM
iapexl8r
07-22-2006 03:43 PM
menzo
1997 - 2003 F150
11-25-2005 03:34 PM
ubermich
06-28-2004 11:42 PM
Blues501
1999 to 2016 Super Duty
07-13-2002 01:00 PM
Quick Reply: 1996 f250 rear brakes
