1978 - 1996 Big Bronco
Brakes?
Old Apr 1, 2009 | 08:31 PM
for46016's Avatar
for46016
Brakes?
I have recently replaced everything on my brakes rotors.calipers,pads on front and drums,shoes,wheel cylinders on rear as well as the master cylinder i had this problem before and after all work when you hit the brakes the pedal slowly goes to floor but if you let off and immediately reapply brakes the pedal is firm and it just doesnt seem like the brakes are what they should be.
Old Apr 1, 2009 | 09:33 PM
garypettengill's Avatar
garypettengill
No guarantees here but it sounds like you might have a bunch of gunk in your proportioner valve. That thing can be dismantled and cleaned out and new "O" rings installed. Also take a close look at any rubber hoses in your system. They get soft over time and will start to expand under pressure.
