Fuel pump block off plate?
Old Mar 8, 2021 | 02:10 PM
RenoHuskerDu's Avatar
RenoHuskerDu
Does anyone know if a 420/6.9 IDI can use a standard Ford big block fuel pump block off plate? NAPA has that but no info on fitment to an IDI.
Old Mar 8, 2021 | 03:42 PM
DarkOverCast's Avatar
DarkOverCast
Iirc it's the 460 block off plate that fits
Old Mar 8, 2021 | 03:44 PM
ford390gashog's Avatar
ford390gashog
Use a BBC block off plate.
Old Mar 8, 2021 | 09:37 PM
90Ford73's Avatar
90Ford73
I had a Mr.Gasket block off plate that leaked like crazy. Changed to a Spectre Performance 42473 and never had an issue. Sealed with the rightstuff, and I used a bunch of washers on my old bolts as the ones it came with seemed too short and I was worried I was gonna drop one inside.
Old Mar 9, 2021 | 05:44 AM
bashby's Avatar
bashby
IIRC, you use a BBC plate and may need to grind one corner a little bit to make it sit flat. I used a gasket as a template to make one from some plate aluminum I had laying around.
Old Mar 9, 2021 | 06:52 AM
RenoHuskerDu
What's BBC?
Old Mar 9, 2021 | 08:33 AM
tecgod13's Avatar
tecgod13
Originally Posted by RenoHuskerDu
What's BBC?
Big Block Chevy
Old Mar 9, 2021 | 11:32 AM
PossumTruck's Avatar
PossumTruck
What would happen if one were to simply leave the old pump in there? Asking for a friend.
Old Mar 9, 2021 | 03:33 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
probably nothing maybe some oil leak if the pump was bad to begin with...I've seen a few that the owner removed the arm on the pump. Just saying
Old Mar 9, 2021 | 03:54 PM
DarkOverCast
When I tried the electric route thankfully I left the pump on because when the electric failed, I was able to hook it back up stock and make it home..
Old Mar 11, 2021 | 05:30 PM
RenoHuskerDu
Thanks guys I went with the Spectre Performance 42473 blockoff plate from Summit Racing that was recommended above.
warricre
Oct 21, 2021 12:43 AM
wreckinball
Jul 17, 2009 01:35 PM
rwlacks
Nov 15, 2008 09:07 PM
KONKILR
Oct 14, 2002 05:19 PM
buddythomashou
Sep 20, 2002 11:30 PM
