Problem with a 87 302..
Old Oct 15, 2000 | 05:42 PM
ummduh's Avatar
ummduh
I just bought this truck with a 302 for $200, so it's not like I'm going to lose money on it. The problem is that it will only run at WOT or goosing it to WOT alot. As soon as you take your foot off the gas, it dies.
The other thing is that it runs VERY rich while your doing this, the fumes starting to burn my eyes.. Wasn't burning any oil.
Guys have any idea what it could be? I'm thinking TPS, idle air control motor, TFI, or fuel pressure regulator.
Thanks,
Matt
Old Oct 15, 2000 | 10:49 PM
PAUL_2's Avatar
PAUL_2
Id start with checking the fuel pressure . Usually when an engine runs that rich its getting way too much fuel & the fuel pressure regulator is often the cause . Depending on how long its been running that way things like the plugs , O2 Sensor may need replacing also .
Old Oct 15, 2000 | 10:58 PM
ummduh's Avatar
ummduh
[font size="1" color="#FF0000"]LAST EDITED ON 15-Oct-00 AT 11:59 PM (EST)[/font][p]Well, the people that were working on it have no electronic experience, and just started replacing whatever was cheapest first.. It hasn't been run much. They said it use to go a few blocks, then die. Wait an hour or so, and it'd do it again. When I checked it out, it wouldn't slow idle at all.
I'll have to check the fuel pressure when i get it to my house tuesday. Whats a good range?
Old Oct 16, 2000 | 10:56 AM
jopey's Avatar
jopey
35-45PSI engine off
30-45 engine running
pressure should increase 5-10psi when you remove the vacume hose for the regulator
Old Oct 16, 2000 | 12:22 PM
Motorcraftsman's Avatar
Motorcraftsman
do you think your timming may be off or not advancing?
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
stock manifolds, w/ staight pipe
Old Oct 16, 2000 | 12:24 PM
Motorcraftsman
or possibly the whole computer is on a downfall?
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
Old Oct 16, 2000 | 12:48 PM
ummduh's Avatar
ummduh
>John Floyd
>South Mills,NC
>'86 F150 2wd 300 6
>Crane Cam 260/272
I was thinking that for a little while, but decided that wouldn't be likely considering that when it ran, it didn't miss, it ran VERY rich.. Generally timing won't make it run that rich..
But still open to all suggestions!
Thank ya,
matt
Old Oct 16, 2000 | 12:50 PM
jopey's Avatar
jopey
possibly worn fuel injectors.
how many miles on the vechile?
Old Oct 17, 2000 | 01:35 AM
ummduh's Avatar
ummduh
102,000 miles on it.. It's easy to tell if the jenctors are gone, has to hold the pressure after the fuel pump is off. Alot of people are saying the TPS also.. Lots of stuff to check out. Just got a scanner for the computer tonight, so I'll be ready for it when I get it.
Thanks,
Matt
Old Oct 17, 2000 | 11:26 AM
billyo's Avatar
billyo
First, check for a large vacuum leak. If OK,
Check fuel pressure - gauge should go to around 38 psi and HOLD when you turn key on (engine off). If it immediately leaks off, remove vacuum line from pressure regulator. If fuel is coming from vacuum port, regulator is bad. If not, suspect injector staying open (injector stuck or wire grounded) NOTE: Use a quality gauge set for this test - If regulator is stuck closed, pressure can exceed 100 psi and burst test hose.
Let me know how this turns out.
O
Old Oct 17, 2000 | 03:26 PM
murphydo's Avatar
murphydo
FossenRacing
Oct 8, 2013 06:47 AM
Pwnm30rdi3
May 20, 2012 10:55 PM
lemonshindig
Jun 23, 2010 09:52 PM
Ducc
31
Nov 4, 2008 07:48 AM
texan_eagle_scout
1997 - 2003 F150
Jan 4, 2003 12:28 AM
