NEED HELP
Old Mar 6, 2021 | 07:52 PM
FordManDan2001's Avatar
FordManDan2001
4wd Low
Exclamation NEED HELP
I have an 01 f250 4x4 freshly rebuilt transmission. Got the transmission put back in and now the truck won’t go over 45 mph. When climbing a hill the truck will downshift but when the rpms raise the speed drops and you almost roll backwards off the hill. When taking off from a stop the rpm gauge gets to 2000 rpm and bad,y starts sputtering. Let of the pedal and it shifts into second. The same with 2nd to third but not as bad. However in low range things works perfectly. Fluid level is good and not low also od light does flash when it’s doing all this. However if I turn the truck off then back on place it in 4 low I can drive all around and have no od light flashing. Please help as I’m stuck on this and this truck is what I use for my business.
Old Mar 6, 2021 | 08:02 PM
timmyboy76's Avatar
timmyboy76
The OD blinking means, there's codes bud relating to transmission..need to read them
Old Mar 7, 2021 | 01:35 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
In addition to reading the codes check the transmission harness and connector, easy to bang stuff when installing a trans.
3000gtman
45
Oct 21, 2016 08:57 AM
theduke308
2004 - 2008 F150
Feb 1, 2012 12:01 PM
iowastroker
Feb 8, 2009 05:24 PM
dcara
Sep 21, 2007 11:29 PM
92 f150300six
Oct 29, 2003 10:02 AM
