4.56 and 38s
Old Oct 26, 2003 | 11:33 PM
92 f150300six's Avatar
92 f150300six
4.56 and 38s
i have a 92 /300ci/e40d just wondering what every one thought will it be runnin high rpms i dont think i will with 38s also will i still have good low end cause she does go mudding
Old Oct 27, 2003 | 02:27 AM
Pkupman82's Avatar
Pkupman82
4.56 is a really low gear! Even with 38s, I would run 4.11 or maybe 4.30s instead. 4.56s would give you all low end but it might hurt you on the highway even with the overdrive tranny. Just my 2 cents!
Old Oct 27, 2003 | 02:46 AM
NM5K's Avatar
NM5K
I show about 2822 rpm at 70mph. "38 inch tire with a 4.56-no OD" I'm not sure what a E40d is...???Is that the EAOD automatic?? If so, and the OD is .67, you would turn about 1891 rpm at 70 in OD. MK
Old Oct 27, 2003 | 10:36 AM
92 f150300six
yea its the auto with over drive man1891rpms are low i thought it would be runing around 2000 + at 70 this is awsome
Old Oct 29, 2003 | 09:58 AM
Ford64Life's Avatar
Ford64Life
I would go with 456s for those 38s. every inch bigger in circumference of tire you go drops your rearend gear 0.1 so say you started outed factory 3.55 and probably about 29 inch tires. 38s are 9 inches bigger. 4.56 - 0.9 = 3.66 gear with that conversion putting you right in the ballpark of factory specs.
Old Oct 29, 2003 | 10:02 AM
FordPerf300's Avatar
FordPerf300
i have 4.56 in my 93 with 35" dunlops, actually measure just at 34" and i take it on the highway, even in OD the rpms at 70 are REALLY high, about 2800. I think 38's would put you right where you want to be with 4.56 gears. I'm also planning on going to 38's next year.
laka
19
Sep 4, 2018 06:55 PM
Jos92
General Diesel Discussion
Apr 10, 2015 11:10 AM
ZombiePopper
13
Feb 28, 2015 05:08 AM
Forest_54_Ford
43
Nov 19, 2013 09:17 PM
