400 cam
Old Mar 4, 2021 | 05:50 PM
77 HOS's Avatar
77 HOS
400 cam
I know irs been beat to death trust me ive read for hours and had one one in mind and dosent see to be made by comp anylonger.
351 building into 400.
everything is at machine shop
ordered .030 over tmi pistons today for it.
Machine shop recommends. Comp 260h
I havent been able to find many threads regarding that specific cam.
any first hand experience with it or any other recommendations.
short bed 4x4
holly 600
Long tube headers
np435/205
Used weekly to pull boat approx 4500 lbs with trailer.
Any help is appreciated. Ive just read so much I think ive confused myself.
Old Mar 4, 2021 | 06:05 PM
440 sixpack's Avatar
440 sixpack
This is easy , custom roller cam.
For about $500 more than a generic flat tappet cam you can get a custom grind roller to your specific engine build and vehicle. not only will you get the improved performance of the roller you can't get in flat tappet ramps but you'll miss out on the cam break in drama . unless you like the suspense or rolling the dice.
I use Brent Lykins he is a ford guru and does a great job but I am sure there are others as well. he can get you a custom grind flat tappet too but I don't know why anyone would.
Old Mar 4, 2021 | 06:07 PM
somethingclever's Avatar
somethingclever
260h would be a great grind for your application
Old Mar 4, 2021 | 07:32 PM
SlikWillie's Avatar
SlikWillie
I ran a Comp 260H cam a few years ago. 5k miles after the break in I decided to change the oil and ran straight Castrol oil with no zinc additive. After about 200 to 300 miles, I wiped a lobe. Now, the 260H cam was great from idle to about 4k rpm and it had a very light lope to it. I loved it but I wanted more. Compare it to an RV cam and you will see there are the same.
After that, I read a lot about the 268H cam and it was very temping to throw that in my engine. People say it is a huge difference and works well with a 600 cfm carb and headers. If I ever rebuild my engine again, I will be looking for a 268H kit.
COMP Cams Camshaft Kits FORD 5.8L/351 - FC 268H-10 Grind Number - Free Shipping on Orders Over $99 at Summit Racing
Old Mar 4, 2021 | 08:00 PM
77 HOS's Avatar
77 HOS
After that, I read a lot about the 268H cam and it was very temping to through that in me engine. People say it is a huge difference and works well with a 600 cfm carb and headers. If I ever rebuild my engine again, I will be looking for a 268H kit.
damn that hurt. Do you know what # cylinder that was?
Old Mar 4, 2021 | 08:42 PM
BLK79's Avatar
BLK79
I remember from the Project Bronco website years ago, 255DEH and 265DEH were two that were both used alot. May not still be avail I don't know.
Old Mar 4, 2021 | 09:28 PM
65f100_352's Avatar
65f100_352
The comp 268 is a great all around cam.. buddy had one in is truck for a lot of years and was very happy with it..
Use diesel rated oil, even now, Chevron delo for example has around 1100ppm of zinc in it..its a great cheaper alternative to higher end oils.. but given the budget allows, no question, roller cam..
Old Mar 5, 2021 | 05:16 AM
SlikWillie's Avatar
SlikWillie
Number 7 exhaust lobe. I run Motorcraft Diesel 10W-30 oil ever since. Has 1000 ppm of zinc. No problems at all now.
Old Mar 5, 2021 | 09:08 AM
CelticOne's Avatar
CelticOne
Regular User
I second contacting Brent Lykins (brent@lykinsmotorsports.com) for a custom ground cam. If nothing else you will get a straight answer from someone who knows what he is talking about.
Old Mar 5, 2021 | 09:21 AM
440 sixpack
The diesel oils like Motorcraft do have around 1000 ppm zinc but Valvoline VR1 has 1300. while 1000 should be enough 1300 is better. what's another $10 an oil change for a little more protection.
The problem is you can do everything right and still eat a flat tappet cam . I'm done with that game .
Old Mar 5, 2021 | 09:24 AM
beartracks's Avatar
beartracks
Depend a lot on your compression ratio!
Old Mar 5, 2021 | 09:47 AM
440 sixpack
That and a lot of other things. that's why custom grinds make so much sense.
The debate between the 258H, 260H , 270H and so forth is in the past. now it's I want a cam for my engine build and specific vehicle for my elevation and intended use . I just feel stupid for being so late in discovering it.
Old Mar 5, 2021 | 09:51 AM
tabascom16's Avatar
tabascom16
I have a 262 duration in a 408W for a 76 Bronco. Even it takes some RPMs to hit a power band so unless you have some upgraded heads, intake, and exhaust you can actually start ruining performance by using too big of a cam. I can only encourage you to read up on lobe separation angle and try a custom cam. A tighter lobe separation angle is shown to boost torque across the entire RPM band (and also get a more aggressive sound due to more overlap). If I had to do it all over again I would have got the 262 lobes ground on a 105 degree lobe separation angle and give it a go.
53.F100
Oct 4, 2019 08:48 AM
79-F350
18
Feb 27, 2014 04:20 PM
towtruck1
25
Jul 1, 2008 05:05 PM
5.0stang
16
Sep 20, 2007 07:49 AM
grego
Apr 26, 2007 02:12 PM
