How do plug solid fuel lines?
Old Mar 1, 2021 | 11:37 PM
NOID4RP's Avatar
NOID4RP
Trailering
I am going to replace my fuel pump on my 59 F100. The fuel lines are solid metal. On all other cars it is easy to block rubber fuel lines. Here I want to make sure I have a solution ready so I don't start spilling fuel everywhere.
Old Mar 2, 2021 | 09:10 AM
JohnNewb's Avatar
JohnNewb
You should have a hose from chassis line to pump. Also, a flex line where fuel line exits cab floor.
Old Mar 2, 2021 | 01:09 PM
f5fordgirl's Avatar
f5fordgirl
If somebody has put solid line to the pump inlet, slip a plug in a piece of rubber hose, when you pull the line off the pump, quickly slip the hose over the line.
Old Mar 2, 2021 | 05:07 PM
Red60's Avatar
Red60
Duct tape off filler tube, strategically place a catch bin, and go for it! If all is sealed, it shouldn’t leak more than a quart.
In all seriousness, a 3/8 line usually fits over the flare and take a 24” piece up the inner fender above the fuel level in the tank.
Old Mar 2, 2021 | 11:08 PM
NOID4RP's Avatar
NOID4RP
Trailering
Thanks guys
D Walker
Feb 20, 2018 06:09 PM
Niveyinc
Sep 4, 2017 06:46 AM
opnjim
1997 - 2003 F150
Aug 5, 2009 09:09 PM
firemanp
Jan 12, 2006 07:28 PM
