Steering binding
Old Feb 28, 2021 | 09:41 PM
reddogg94602's Avatar
reddogg94602
Steering binding
Hi there I've a 71 f250 camper special it tracks well most of the time but on turns it gets tight any thoughts?
thank you.
Old Mar 1, 2021 | 09:38 AM
Alex from GA's Avatar
Alex from GA
Jack the front up, disconnect the pitman arm and turn the wheels lock to lock by hand. Is it the front end or the steering box/
Old Mar 1, 2021 | 10:25 AM
sparky72's Avatar
sparky72
Check the rag joint and the steering column alignment with the steering box.
Old Mar 1, 2021 | 07:45 PM
reddogg94602
Okay thanks I'll give it a try the next couple days hopefully it straightens it out.
Old Mar 1, 2021 | 08:05 PM
reddogg94602
What's a rag joint I've never heard of that
Old Mar 1, 2021 | 08:26 PM
Christmas's Avatar
Christmas
That thing between the steering column and steering box.
Old Mar 2, 2021 | 07:40 AM
Coastal68's Avatar
Coastal68
Here's a couple of FTE threads dealing with the subject of rag joints:
https://www.ford-trucks.com/forums/1417546-71-72-rag-joint-steering-coupler-replacement.html
https://www.ford-trucks.com/forums/1234129-1971-f100-rag-joint-help.html
Old Mar 7, 2021 | 02:47 PM
JEFFFAFA's Avatar
JEFFFAFA
It could also be the king pins are binding. Put some grease in their zerk fittings.
Old Mar 23, 2021 | 09:29 PM
reddogg94602
Replace the power steering pump and it solve the problem thanks for the information guys and gals.
Old Apr 16, 2021 | 11:59 AM
reddogg94602
Anybody see this before?
Old Apr 21, 2021 | 05:39 PM
reddogg94602
Don't worry it's been replaced new box new pump
Old Apr 22, 2021 | 09:21 AM
fe390pc's Avatar
fe390pc
Wow is all I can say. Lucky it didn't bind solid on you.
Old Apr 22, 2021 | 06:08 PM
reddogg94602
Just a bad pump ended up replacing pump and gearbox.
JoeJJones
Sep 30, 2014 10:21 PM
J1MMY
Apr 10, 2009 10:28 PM
77-250
Apr 16, 2008 02:33 PM
tonygray
Jul 31, 2006 09:19 PM
i looove fords
Mar 4, 2003 01:30 PM
