Forscan "Crawl" mode in a non-Tremor
Can Forscan turn on "crawl" mode on a non-Tremor? Other super duties have the hill decent witch is virtually the same thing, but can the uphill part of that be added?
Someone said it should in the 2017+ fb group, and figured it makes sense, but you guys would know. That's about the only aspect of a tremor that appeals to me.
There is a bunch of conversations.
https://www.ford-trucks.com/forums/1...readsheet.html
ZooDad
Dont think you scrolled down far enough.
ZooDad
ZooDad
If I can get part, calibration and strategy numbers from a tremor it may be in that
ZooDad
or maybe just a 2wd low mode? I saw someone used an upfitter to engage 2wd low but would be real nice if it could be engaged via the drive mode switch.
**edit - my google education explains rock crawl mode is used when operating in 4wd low range. It’s enabling a mode in the transmission, so maybe it could be programmed via forescan (?). https://media.ford.com/content/fordm...d-package.html
Side note: I did the 2lo mod to my truck. I don't use it often but it is handy when I do.
See link below. Super simple to do if you have upfitter switches. Can still be done without but upfitters make it easier.
https://www.ford-trucks.com/forums/1...rride-mod.html
If it is like what in the Raptor I had it will need to use the Sync three screen and front camera to show you what is in front of you. I used it twice on my Raptor in the time I owned it. When I went to Raptor Assault we used it going up and down the mountains. Set it a three miles an hour and forget it either going up or down.
I could see using it more if I did some serious mountain trails. I really didn't see any benefit to it on any other type of use.
Not sure it is like the Raptors
Mike
Mike
