Switch Problem?
Old Feb 25, 2021 | 07:01 PM
Colemater's Avatar
Colemater
Switch Problem?
Turn the key today and got nothing - no lights, no sound, no solenoid popping
replaced solenoid and battery this summer
12 v at the battery
is it my switch?
thanks in advance
Old Feb 25, 2021 | 07:44 PM
dlburch's Avatar
dlburch
headlights work? does the horn work?
Old Feb 25, 2021 | 09:09 PM
jakeharp's Avatar
jakeharp
Is it an Auto? Mine likes to play games with the 'park' selector, if its not in its special place i get nothing from the ignition...
Old Feb 25, 2021 | 09:22 PM
72rtchallenger's Avatar
72rtchallenger
Check linkage for tranny , make sure its in park good and that neutral switch is working
Old Feb 25, 2021 | 11:20 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2, when you get a no nothing at all issue. Honk horn and check if headlights come on. I bet they do. So ok so you have 12v at battery. Time to make sure you have it in park and the NSS is working not broke /loose. Yours should be under the dash and on top of the steering column.
This one is missin the tab to move the switch plunger.
This one has the tab.
Old Feb 26, 2021 | 08:51 AM
meangreen92's Avatar
meangreen92
Check your fusible link. When mine went, I didn't have any power in the cab. I didn't think to try the horn, but it is wired independently of the fusible link, and should work if the FL burns out or opens. My truck had no headlights when the FL blew.
Old Feb 26, 2021 | 03:11 PM
HoustonDave's Avatar
HoustonDave
another quick check, see if you have juice to the solenoid when you turn the switch - the solenoid is just a big relay and only powers the starter when it gets juice on the activation circuit. You should get juice through the switch to one of the smaller posts on the solenoid when you turn the switch to 'start' - if so, your switch etc. is probably good. If you don't have juice from the solenoid to the starter then, your solenoid is probably bad.
Old Feb 27, 2021 | 06:45 PM
Colemater's Avatar
Colemater
thanks all - problem solved
was a loose battery post
thank goodness - easy fix
bryonwleeper22
15
Jul 22, 2014 09:16 AM
Mbuchanon19
Mar 16, 2011 08:59 PM
0351mike
Sep 5, 2010 07:10 PM
PrintNCut
15
Aug 2, 2009 06:50 PM
ramarado
Oct 30, 2007 03:20 PM
