Ignition Switch or what?
Old Oct 29, 2007 | 09:51 PM
ramarado's Avatar
ramarado
73 F-100, put new starter and solenoid on fender + new battery, whenever I turn the switch however, nothing happens. No click but dash lights come on. It will start right up by shorting across the solenoid, and will die whenever I turn the key off. Could it be the ignition switch itself or possibly a neutral control switch?
Old Oct 29, 2007 | 10:14 PM
gnwalker's Avatar
gnwalker
make sure the the clamps on the battery cables are tight on the battery posts, its happened to me
Old Oct 29, 2007 | 10:15 PM
ramarado's Avatar
ramarado
It's a new battery, cables, etc. , all is tight.
Old Oct 30, 2007 | 01:46 PM
wintremute's Avatar
wintremute
Replacing the ignition switch is cheap enough, so I'd try it. On mine, the neutral safety switch is wearing out and sometimes I have to jiggle the shifter around before it will start.
Old Oct 30, 2007 | 03:20 PM
Mil1ion's Avatar
Mil1ion
2 different systems It just means that power is gettingto the fuse box
Try jumping the NSS circuit then try the key again.
Wiggling the shifter helps as well.
