It worked - then didn't
Old Aug 1, 2009 | 06:15 PM
PrintNCut's Avatar
PrintNCut
had power & next it didn't. battery is new, turn key switch on - nothing. did some jiggling last night and did get it running again. today nothing. something between switch & ???
Old Aug 1, 2009 | 06:38 PM
uncle.stosh's Avatar
uncle.stosh
Check the big yellow wire with the fuseable link off of the alternator.
I'll bet it's all corroded and toasted.
Old Aug 1, 2009 | 07:34 PM
PrintNCut's Avatar
PrintNCut
I'm no mechanic for sure stosh but from what I saw it was ok. I'm talking no dash lights or anything when you turn on the switch as if there were no battery at all
Old Aug 1, 2009 | 08:03 PM
86bigred's Avatar
86bigred
clean your battery posts and make sure all connections are clean and tight.had this happen to wife's topaz the other day.she got in turned the key it went click and everything went dead.cleaned battery terminals,problem solved.
Old Aug 1, 2009 | 08:12 PM
PrintNCut's Avatar
PrintNCut
good suggestion but I just put the battery in - it's brand new, even went to the extent of replacing the starter relay - no luck
Old Aug 1, 2009 | 08:18 PM
86bigred's Avatar
86bigred
are the clamps clean.the po on the topaz put a new battery in it and it still did this.plus if the clamp is one of those quick repair,where you clamp the wire on,the cable could be corroded.
Old Aug 1, 2009 | 09:12 PM
PrintNCut's Avatar
PrintNCut
As far as the power supply part of it, everything's new. The only thing I can figure is that something has to be grounding out somewhere else. The damn thing acts like the battery has been taken completely out of the circuit
Old Aug 1, 2009 | 10:05 PM
Spennyman84's Avatar
Spennyman84
Hey,
I had the same problem but it was my solenoid. Had no power,lights,nothing.... The positive wire from the solenoid was just loose enough to kill everything. I tighten it up and she fired right up. Be careful if you tighten them they break very easy.
Old Aug 1, 2009 | 10:35 PM
PrintNCut's Avatar
PrintNCut
I'll take a look at it tomorrow & c but I'm gonna grab a new cable anyway - can't hurt
Old Aug 1, 2009 | 10:36 PM
Franklin2's Avatar
Franklin2
Will the headlights work? If not, no matter what is new, go out and clean and check all the battery connections, and like the other poster said, the large connections on the solenoid. Take a knife and scrape the battery connectors.
Old Aug 2, 2009 | 06:09 AM
uncle.stosh
I had the same exact problem with my truck.
The entire fuse block is fed by the large yellow wire that is in that bundle over near the alternator. Don't rule it out just because you did a visual inspection.
Make sure you have 12V to the main fuse block from that wire or you will get nothing. You can pierce the wire with something sharp and check both sides of the fuseable link.
Old Aug 2, 2009 | 06:16 AM
PrintNCut's Avatar
PrintNCut
Gotcha stosh. I'm gonna start from the solenoid and work out & see what happens wire by wire
Old Aug 2, 2009 | 06:20 AM
uncle.stosh
Sorry, double post.
Old Aug 2, 2009 | 04:17 PM
PrintNCut's Avatar
PrintNCut
stosh - new pics in my album, can't post here
Old Aug 2, 2009 | 05:28 PM
PrintNCut's Avatar
PrintNCut
All wires and fuses check out for continuity and connections are tight. The high current power wire's fuse is good. There is still no power to anything even when hot shotted
