Something to share with everyone
Old Feb 16, 2021 | 11:51 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Okay I was working on getting some heat into both trucks do to all the moisture we have here now.
I semed to have picked up a lot of water in both trucks. So a heater went into the one without an engine.
The other one I just plugged in the block heater. So for giggles I grabbed my FLIR camera and took this
photo of the bleok heater in action. I took the photo after it had been plugged in for about 30 minutes.
It is 41º out side right now and that engine was stone cold when I started.
That tyellow glow is the heater tube and it was warm to the touch. Also the inside of the cab was feeling a bit warmer than the outside air.
One thing I have done is put some of the desiccant packs in both trucks. The one from the truck that runs needed to be recycled and so I stuck one
the other large packs I have for now.
Anyway I thought you all might find it interesting to see the IR photo. The lower side through the wheel well on the passenger side was also quite hot.
But when that is where the heater lives it's going to warm up fast.
Old Feb 17, 2021 | 01:25 AM
Hartwig's Avatar
Hartwig
Which IR cam do you use? Do you have a photo of the driver side?
Old Feb 17, 2021 | 03:54 AM
Yahiko's Avatar
Yahiko
FTE Remembers
FLIR E4
The driver side was not showing much heat yet.
Old Feb 17, 2021 | 06:30 AM
IHateCommieCars's Avatar
IHateCommieCars
I definitely feel my block heater in the cab in the morning.
Old Feb 17, 2021 | 06:48 AM
TooManyToys.'s Avatar
TooManyToys.
Yeah, I have too. It ain't just for engines on a really cold day. Of course, I didn't have a vacuum valve on the heater input hose.
Old Feb 17, 2021 | 07:08 AM
IHateCommieCars
I assume it's not a bad idea to leave the block plugged in when you're working on it out in the driveway on cold days. Like a little mitten warmer.
HILLBILLY BOB
Feb 4, 2015 09:57 AM
StevenK
Apr 27, 2007 10:42 AM
Leykis101
20
Feb 22, 2006 09:37 AM
ford390gashog
Nov 22, 2004 06:34 PM
Black_Bronco
1978 - 1996 Big Bronco
Oct 11, 2002 06:37 PM
