Sponsored by: Real Truck
replace hazard flasher with wigwagger?
Old Feb 16, 2021 | 12:49 PM
diymirage's Avatar
diymirage
hey guys
i have an 05 F350 i use as a plow truck
would i be able to pull out the hazard flasher relay and wire in a wigwagger module there?
i guess the real question is "is there a dedicated positive lead for the left as well as the right side of the truck hooked up to that relay" ?
(id prefer not to run 80 yards of extra wiring to get this done)
thanks
Old Feb 16, 2021 | 06:17 PM
projectSHO89's Avatar
projectSHO89
Short answer - No. You will need external circuitry.
Old Feb 17, 2021 | 11:42 AM
nydiver's Avatar
nydiver
For true wig wag you need to get right to the bulbs, the turn signal flasher module is just a small timer circuit to interrupt the power to the turn signal bulb selected.
I always used soundoff modules but everyone (fed sig, whelen, star, code 3, etc) makes modules. Pretty easy to do once you find the positive wire on each bulb, You just tie into them and put them on the outputs of the module, then switch power to the module to turn the wig wags on and off (always best to also add diodes to the wire before the tie in so you can't back feed power while using the wig wags).
Here in NY its illegal to have a flashing primary light and wig wags on at the same time, regardless of colors. Hideaways also can't use wig wag patterns, the 2 corners need to be flashed at the same time. Its believed that wig wags can fool people into thinking its legitimate police and pull over. Some people might use this for nefarious reasons
Old Feb 17, 2021 | 12:08 PM
diymirage's Avatar
diymirage
i was hopping not to have to tie into each individual bulb...if i do that i might as well retrofit some additional lights into the truck and work with those
i figured since all lights are activated by one switch on the dash, there has GOT to be a way to replace that switch (or put in a 3 position switch) and run wig waggers using the stock wiring
or perhaps there is a left side /right side fuse somewhere i can tap into
Old Feb 17, 2021 | 12:22 PM
nydiver's Avatar
nydiver
The left and right turn signals are in the column loom. When you move the stalk it creates a contact that flashes the proper bulb. The separate wires are there in the cab, just finding them can be a bit time consuming. Also if you tie in there at the column you'll likely get front and rears wig wagging and you definitely need the diodes in the circuit to eliminate back feed. Always did mine under the hood and in the trunk with diodes.
6_Myles
Jul 23, 2020 07:27 AM
noober0x
Oct 30, 2015 07:04 PM
Big Big Blue
Jan 15, 2015 08:16 PM
rustyculley
Oct 5, 2012 02:13 PM
HoustonGuy
Apr 1, 2011 01:35 PM
