Headlight wiring
Old Feb 13, 2021 | 08:20 PM
Taurus2415's Avatar
Taurus2415
Trailering
Headlight wiring
2020 F-250 Lariat with halogens. I was changing out the stock bulbs for the Sylvania Ultras and did not pay attention to the wiring harnesses. One of the plugs has a grey sheath and the other is black. Which of those goes to the top bulb in the assembly? Or does it matter? Thanks.
Old Feb 13, 2021 | 08:40 PM
2020STX250's Avatar
2020STX250
Go to the 5:50 mark. They have the assembly popped out with the wires showing. Gray on top.
Old Feb 13, 2021 | 08:47 PM
Taurus2415's Avatar
Taurus2415
Trailering
You da man. That’s perfect. Thanks!
Old Feb 13, 2021 | 08:51 PM
2020STX250's Avatar
2020STX250
All those hours on YouTube paid off 🤣
Old Feb 14, 2021 | 07:14 AM
Poncho450's Avatar
Poncho450
Too late now because you've already done the job. But I've swapped bulbs many times on a 6.2 and there's no need to remove the grille. At most, the washer tank filler neck and air breather snorkel. Got so I could do all 4 bulbs in about 15 minutes.
Old Feb 14, 2021 | 02:28 PM
Taurus2415's Avatar
Taurus2415
Trailering
You are correct and that’s what I did. The passenger side is easy after you get the air filter box out of the way. The drivers side lower bulb is a bear to reach. I was in a hurry and didn’t note which connector went where though. Sigh.
Old Feb 14, 2021 | 03:20 PM
Ding126's Avatar
Ding126
top and bottom bulbs & harness are the same?
Old Feb 14, 2021 | 03:54 PM
Taurus2415's Avatar
Taurus2415
Trailering
The connectors are exactly the same (H13) but one bundle is wrapped in black sheathing and the other (top) is wrapped in grey. The side marker and turn signal bulb connectors are different. Can’t mess those up.
Old Feb 15, 2021 | 07:23 AM
Poncho450's Avatar
Poncho450
I mainly posted that because another post shows a video of the guy sitting there with the grille in his lap. Totally unnecessary and a waste of time on a 6.2 truck.
Even on my 7.3 with dual batteries I did it by removing the washer tank filler neck on the driver side, and the whole airbox will pull out on the passenger side after disconnecting the tube that connects breather to intake.
BiggB20042001
Dec 6, 2024 08:23 AM
1949 School Bus
Mar 25, 2020 01:55 PM
7.3powerstrokeBob
Jan 6, 2020 12:51 PM
gunner360
2015 - 2020 F150
Feb 14, 2018 06:57 PM
austind_05
2004 - 2008 F150
Dec 9, 2005 07:40 AM
