New Engine Break In
Old Feb 10, 2021 | 09:46 AM
  #31
diggerrigger's Avatar
diggerrigger
Another way to look at breaking in the engine. With a flat tappet cam, the cam break in is the most critical. Do it wrong, you're asking for trouble. Do it right, rings and everything else will be happy too. Cam manufacturers know cams. Every cam manufacturer will provide break in instructions for their product. If you already have your new cam, break in instructions are in the box with it. Best practice is to do what your cam's manufacturer suggests for their product.
Old Feb 10, 2021 | 09:53 AM
  #32
BlueWhiteFord's Avatar
BlueWhiteFord
Yeah, for the cam itself, I will stick to the instructions and use the break in oil and all the rpm values they give.
I feel like if get through the cam break in without it comming out of the pan with the oil, I will be a good way on the road to a long lasting engine.
Just trying to get some input from people that might have done this before, as this is the first time I have done this.
Old Feb 10, 2021 | 10:50 AM
  #33
diggerrigger
I just broke in a rebuild with a used roller cam. I used Valvoline Racing 10W-30 for about 200 miles and changed to Pennzoil 10W-30. Don't know if this was a good idea or not. It's done. I will use the Pennz for at least the next two oil changes because that is what I have on the shelf. With 400 miles or so now, compression is even. Won't know about anything else for a while.
Myers B
Jun 3, 2020 08:14 PM
RIKIL
15
Aug 22, 2011 06:09 PM
Dan92
Nov 29, 2010 06:35 PM
DeereTech05
Aug 26, 2010 07:02 AM
TopSgtLawrence
Engine Swaps
Mar 10, 2008 04:13 AM
