Anyone have some good advice for this? I have never done it before so I was going to go with what has came in the literature with the various parts I have received. Basically I was going to get some breaking in oil and run that for 30 min. Drain that oil then put in "regular" oil and replace the filter with the standard stock replacement. Suggestions on what oil I should use after the breaking in oil? What brand, type, weight?
This will be for a high performance 351W going into a 92 F150.
i believe that royal purple has break in oil. im not sure what weight or anything, but it says break in oil on it. haha. and then i would probably run 10w30. but i would use royal purple on that too, just caust its a new motor. but quarts of 10w30 are $10!!!
With a new cam and lifters be sure to set your static timing *before* firing the engine and after having removed the distributor to prime the oiling system with a socket on a drill.
Start the engine and immediately run it up to 2500rpm and don't let it drop for the first 20 minutes.
This will ensure enough oil flow to keep from wiping a lobe or lifter.
Don't do the rest of your break in at a steady speed like on the highway. Vary rpms and gradually increase both the RPM's and load over the first few hundred miles.
Change the oil and filter after the first hundred miles and then five hundred after that.
You should be okay from there to use whatever oil, and change interval, you intend to use for the life of the engine.
In answer to the OP, I use regular Rotella T 15W-40 in the summer when I can find gallons on sale at WallyWorld. (they have Motorcraft filters cheap too)
I use nondetergent strait 30 wt oil(air compressor oil) and a zink additive when breaking in a motor. Run it above 2500 rpms for half an hour. I vary the speed as time goes on too.
My motto is "It will go or it will blow". I run it to the max rpm range for the cam in short bursts when closer to the end of the break in time.
Flat tappet or roller cam? That's the main deciding factor. I change oil at 50 miles and then at 500 miles, just to be safe, and I use cheaper 10w-30 (like regular valvoline).
It's a roller cam and what I read in some of the reading material that came with the heads or cam is that I should run the motor for 30 min to get all the metal shards off the edges of things like the cam and pistons, if there are any loose shards of metal. It didn't list any special type of oil but, based on what has been said here, I was going to use a premium, non-synthetic 5w30 for the first 30 min and then use a good oil for 500 miles and then I will go to the normal schedule of oil changes.
There shouldn't be any metal shards on anything? Everything should be as clean as possible for assembly. The only reason I change the oil at 50 miles and 500 is to check for problems, and get any dust or dirt cleaned out of there (dust is in the air when you are assembling the engine, it can't be helped).
