Sponsored by: Real Truck
Heating problem
Old Feb 14, 2021 | 09:50 AM
super 6.8's Avatar
super 6.8
You should have one on passenger side up high in the engine compartment with a vacuum hose going to it. It is inline to the coolant hose going to the heater core. I believe if someone has removed this you would have heat all the time even if A/C is turned on.
It could cause the problems you are having either by inconsistent vacuum or a dirty sludged up valve that can't open fully.
Old Feb 14, 2021 | 10:02 AM
F350 1990's Avatar
F350 1990
Likelihoods (probabilities of problem source):
Low engine coolant -- low
Engine overheating (assuming your temp gauge, sensor (you have two in 5.4Ls -- one on the head that feeds the PCM and one on the intake that feeds the dash) and thermostat are functioning "ok" -- you can "instrument" with free OBD2 tools see the head sensor values) - low to zero probability
Plugged or partially plugged heater core -- low to mid
Temp blend door sticking / binding -- mid to high
A/C blend door actuation - mid to high
Incorrect heater valve operation -- mid to high --- use a hand held IR Temp Gun (I use my Fluke daily as a general purpose (almost everything on vehicles) troubleshooting tool) to verify temps in/out of valve
Old Feb 14, 2021 | 02:19 PM
projectSHO89's Avatar
projectSHO89
It is unlikely that this truck left the factory with a heater control valve.
Sure, you can put a piece of cardboard in front of the radiator. Let us know if that helps.
Old Feb 14, 2021 | 02:37 PM
Walter75's Avatar
Walter75
Hi guys
I went out this morning and looked for the vacuum hose for the heater control valve. I did not find one. I owned this truck since November 2019 and never seen the heater control valve.
I did put a piece of cardboard in front of the radiator.
Old Feb 14, 2021 | 03:48 PM
super 6.8's Avatar
super 6.8
If you can, take a picture of the engine compartment while standing next to the passenger front tire. Post it here.
Old Feb 14, 2021 | 05:55 PM
F350 1990's Avatar
F350 1990
[QUOTE=projectSHO89;19732882]It is unlikely that this truck left the factory with a heater control valve.
Actually, they do -- I owned one (2000 F-250/ 5.4L) that came from the factory with the heater control valve. I also repaired one some months back -- a 1999 F-250 with the same part number.
Old Feb 14, 2021 | 06:26 PM
super 6.8's Avatar
super 6.8
[QUOTE=F350 1990;19733202]
I think the guy meant left the factory WITHOUT a heater control valve.
Old Feb 15, 2021 | 05:50 AM
projectSHO89
[QUOTE=super 6.8;19733245]
Unlikely that is what was meant since, if there's no heater control valve, then it cannot cause the OP's symptom of diminished heat at highway speed.
Old Feb 18, 2021 | 12:09 PM
rouxfarm's Avatar
rouxfarm
Did you install aftermarket heater core. I have seem several cases were aftermarket heater cores on Ford would not put out hot heat when temperature drops into teens and lower. I would go back with motorcraft heater core.
Old Feb 18, 2021 | 01:35 PM
FUN2DRV's Avatar
FUN2DRV
Check your bottom radiator hose. Hoses often soften with age and can sometimes collapse (water pump suction side) when running at a constant rpm for a duration (highway driving), as opposed to stop and go driving in town. This could explain why you have heat when driving in town and not on the highway.
daddylee100
Jan 17, 2014 05:23 PM
Nov 27, 2012 06:00 PM
pjscar429
1997 - 2003 F150
Dec 7, 2011 12:09 PM
ddbuggins
Jan 21, 2005 09:59 PM
marland 96 F-150 5.8
Oct 23, 2004 11:42 PM
