Unknown wire
Old Feb 7, 2021 | 08:31 AM
Dwilliams2996's Avatar
Dwilliams2996
Unknown wire
Hi, I was installing a new air intake and I noticed this harness after I finished installing the air intake. I looked on top of the engine and the valley to see where it goes, didn’t have any luck. Any help would be greatly appreciated.
Thanks in advance.
Old Feb 7, 2021 | 12:12 PM
farmert's Avatar
farmert
Can't tell for sure, but probably goes to the exhaust back pressure valve, that the previous owner unplugged to keep the valve from closing unexpectedly. It is not really needed.
Old Feb 8, 2021 | 08:03 AM
TheFecalFanatic's Avatar
TheFecalFanatic
You are correct. This is for the EBPV on the turbo pedestal.
Diesel O rings has a resistor you can wire in to stop it from throwing a soft code. Otherwise don't worry about it since it won't throw a CEL.
Old Feb 8, 2021 | 08:05 AM
TheFecalFanatic
Also, what's going on with the orange intake boot on the turbo compressor?
Old Feb 8, 2021 | 01:09 PM
Hit Man X's Avatar
Hit Man X
Orange boot needs to go as they are notorious for splitting.
Riffraff makes a boss one and plenum boots. Get that $1 oring for plenum to turbocharger while in there and may as well reseal that CCV 'doghouse' while access is easy.
Old Feb 8, 2021 | 01:48 PM
duck fan's Avatar
duck fan
Because racetruck
I agree, this is the kit you need.
https://www.riffraffdiesel.com/riffr...nd-y-boot-kit/
Old Feb 8, 2021 | 04:49 PM
JayTheCPA's Avatar
JayTheCPA
In addition to resealing the CCV doghouse, consider cleaning it with solvent as well. If doing this, plan on buying a set of hose clamps as the OE ones are not re-usable. Might want to also consider a new hose elbow (connects the doghouse to intake) as it is only a few $ more.
I just did this on mine and it reduced the amount of smoke that comes out from under the dipstick.
Dew_hickey
Dec 15, 2020 08:14 PM
raptor131
Mar 4, 2017 12:54 PM
sunbird79
Apr 9, 2013 10:10 PM
low54
18
Sep 4, 2010 05:07 PM
AlbusPlaustrum06
2004 - 2008 F150
Aug 12, 2009 01:37 PM
