Sponsored by: Real Truck
Wipers not working
Old Feb 6, 2021 | 11:10 AM
MCHOBBS's Avatar
MCHOBBS
Trailering
Wipers not working
2012 F-450 XL 150,000 m.
A month or two ago I started having an issue with the wipers not coming on. If I would turn the switch to on, they would eventually start working and continue to work. Initially, the delay was brief. Later I might drive several miles before they would start working. More recently, they do not come on at all. The washer doesn't work either. As a basic place to start, I checked the mini spade fuse in the passenger side toe kick, and replaced the "cube" fuse under the hood. Any suggestions on where else to look? Thanks, Ford Truck Enthusiasts!
Old Feb 6, 2021 | 01:26 PM
Just Strokin's Avatar
Just Strokin
Probably need to replace the multi-function switch (wiper switch)
Old Feb 6, 2021 | 01:53 PM
MCHOBBS's Avatar
MCHOBBS
Trailering
Thanks. Is that a DIY proposition? FWIW I have been pretty deep in the steering column on my 2002 Ram--replaced the clock spring. Maybe that's not all that deep.
Old Feb 6, 2021 | 02:01 PM
MCHOBBS's Avatar
MCHOBBS
Trailering
Maybe this from @Bramage ? Is '05 the same as '12?
https://www.ford-trucks.com/forums/1...-easy-way.html
Old Feb 11, 2021 | 06:33 PM
MCHOBBS's Avatar
MCHOBBS
Trailering
Update: I replaced the turn signal/wiper switch and the wipers still don't work. What's next? Wiper motor? Thanks!
mattdoc88
Nov 20, 2017 11:16 AM
DocRoche
Aug 17, 2015 08:30 PM
AbandonedBronco
1978 - 1996 Big Bronco
Oct 12, 2013 06:03 PM
wxbean
Feb 27, 2005 10:58 AM
