56 Cab Mounts
Old Feb 5, 2021 | 10:54 PM
smallello's Avatar
smallello
Are we there yet?
56 Cab Mounts
I finally got around to replacing my cab mounts. The rubber that I removed was hard as a rock and brittle.
As you can see I have the old and new parts side by side. There were 2 shims under the cab mount retainer. I assume I should put them back where they were?
Also, I found a square metal block under the nut instead of a washer with a square rubber bushing. Do I still use that block with the round bushing or just use the washer that came with the new hardware from Mid-Fifty?
Old Feb 6, 2021 | 08:48 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You’ll probably have to shim the mounts once everything is back together. I think the original mounts had the square “washer” but the stuff that comes with the new mount kit works fine as is.
Old Feb 6, 2021 | 09:00 AM
56panelford's Avatar
56panelford
The kit I got came with square washers...
Old Feb 6, 2021 | 12:39 PM
smallello's Avatar
smallello
Are we there yet?
Thanks guys
EBEAR
26
Mar 13, 2022 02:37 PM
69 Crewcab
Dec 31, 2018 03:17 PM
saauvenshine
1947 and Older Ford Trucks
May 15, 2017 08:46 AM
MNMIKE300
Feb 11, 2011 10:12 AM
nkapphahn
Apr 7, 2009 11:20 AM
