53 CAB MOUNTS
Old May 12, 2018 | 03:48 PM
EBEAR's Avatar
EBEAR
53 CAB MOUNTS
The PO had about 10 thick washers holding the front of the cab up . I bought a cab mount rubber kit from steele rubber but I'm not sure I have everything else . Does anyone have an exploded view of the cab mounts ? There are also 2 L shaped rubbers and 4 small rubber tubes wich I cannot find a home for .
Old May 12, 2018 | 04:01 PM
56panelford's Avatar
56panelford
1953-56 Ford F-100 Cab Mounting Kit, Rubber Pieces Only - BAAA-5400-S
I think this exploded view from Midfifty should explain it for you.
Old May 12, 2018 | 04:03 PM
EBEAR's Avatar
EBEAR
Here is the kit .
Old May 12, 2018 | 04:05 PM
56panelford
Top four are for the front mount the bottom four are for the rear..
Old May 12, 2018 | 04:15 PM
jniolon's Avatar
jniolon
old and in the way
there is a metal plate or two you need on the front
Old May 12, 2018 | 04:38 PM
EBEAR's Avatar
EBEAR
Ya I think I may be doing some modifying they don't go like I would have guessed and the PO had a huge stack of washers . I made motor mounts etc with minimal clearance on the trans . My project right now was to roll the cab back sand blast and undercoat the bottom of the cab and I knew that he did not have it correct but the fenders fenders-front end seemed to line up ok so I wasn't really concerned .
Old May 12, 2018 | 04:51 PM
EBEAR's Avatar
EBEAR
Oh goody I also do not have the large coned washers that I will assume go under the small rubbers and on top of the frame mounts . I do have the larger plates . Not that they are that specialized and they may be in boxes of assorted . It's odd that there is no rubber isolator under the cab mount . Or does the smaller rubber and washer go under the frame mount which is where it makes more sense to me .
Old May 12, 2018 | 05:35 PM
EBEAR's Avatar
EBEAR
OOPS had a better look at the second pics from mid fifty and it shows it underneath the frame mount as I felt it should be .Thanks for the help guys .
Old May 12, 2018 | 06:25 PM
56panelford
If you look at that Midfifty pic again the large metal cup washer is welded to the bottom of the cab, next is the large rubber pad, then the other metal washer that helps line the mounts to the frame brackets with the smaller rubber pad between it and the frame bracket..
Old May 12, 2018 | 06:34 PM
EBEAR's Avatar
EBEAR
Ok in jniolon"s pic the bottom two cupped washers should be against the cab floor . There is definitely nothing welded to the bottom side of my floor . I was also curious that there was no extra support at the cab bottom .
Old May 12, 2018 | 06:46 PM
56panelford
If you look close on this picture you can see where those cups are attached to the cab..
Old May 12, 2018 | 08:00 PM
EBEAR's Avatar
EBEAR
Ok I got it now thanks again John .
Old May 13, 2018 | 07:14 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
The cup is welded to another piece from the factory. It doesn’t go directly to the floor. This picture shows the other piece, with cup attached. Without the other piece your cab will sit too low in the front to get your front clip to line up properly.
Thanks MIDFIFTY
Old May 13, 2018 | 11:58 AM
EBEAR's Avatar
EBEAR
Hard to tell how high that is without seeing from the side , but it's starting to make sense why the PO had a huge stack of washers in there . Are the plates with washers " they appear to be spot welded already " available separately or am I back in manufacturing mode ?
Old May 13, 2018 | 12:10 PM
Indybeer's Avatar
Indybeer
It appear the cup is available
