I have a 1969 4x4 crewcab and am looking for cab mounts. On this site there are poor reviews of the rubber products offered by LMC . I have checked Dennis Carpenter and their kit is 2 wheel drive only. Since I have a crew i will probably need two additional mounts , but wanted to start with a 4x4 mount set. Does anyone have a source for quality Body mounts ?
My 1970 crew only had the four cab mounts. Two up front and two in the back. Should it of had more? It’s been awhile since I took it apart. Also if there a diffence in the mounts between a Crew cab and regular cab? How about 2wd to 4x4? Thanks. I’ll try not to hijack your thread but I’m in the same boat.
I went Poly for mine. Energy Suspension has the right ones but not the metal sleeves. About 20 years ago I ordered a full set of mounts from Ford so I have new sleeves and Rubbers as well as the Poly bushings. And if you have to replace the actual cab mounts on the cab, buy them from Dennis Carpenter!
