2003 7.3 Fuel Gauge Problem
longtime lurker and reader but never poster.... this site has helped me diagnose / fix things on my 7.3 since buying it 4.5 years ago.
2003 7.3 4x4 38 gal tank 151,000 miles
So my problems started about 3 months ago with a faint fuel gauge jump between 1/2 and 3/4 tank (about an 1/8 jump in either direction. Once the fu gauge got below 1/2 it worked fine... then over the last 3 months it started getting worse and staying in one position for 60+ miles before jumping again 1/8 at a time in any direction between 1/4-3/4 of a tank.
This forum is exactly my problem, however the fix was never discussed.
https://www.ford-trucks.com/forums/1...e-problem.html
I then researched this forum regarding the problem and found this guide and followed it to the T.
https://www.ford-trucks.com/forums/1438365-sending-unit-repair-success.html
After replacing the sending unit the problem still persist and requires me to park the truck and shut it off for 5+ minutes to get an accurate reading upon restarting. Once I begin driving the gauge will either stay in one spot or jump erratically 1/8 in either direction until stopping in one spot again. This will happen from empty to full and not in a distinct area of the gauge.
I would appreciate any help and or guidance with fixing this issue. I am not super savvy at electrical but can test ohms and volts if required, would just need some guidance.
thanks everyone!
