Fuel gauge problem
Old Sep 5, 2011 | 11:49 AM
Sparky0486's Avatar
Sparky0486
Fuel gauge problem
I have problem, my stock fuel gauge has a fluxation problem. At first start the fuel gauge is at one level and then when Im driving it will jump up a 1/8 to 1/4 tank and go's up and down
Old Sep 5, 2011 | 11:58 AM
timmyboy76's Avatar
timmyboy76
think you need to add more fuel. At 1/4tank, your fuel is about atmost 1/2in layer, laying bottom in tank, the slightest peadel, whether gas or brake, with slosh it around, making the float do funny things
Old Sep 5, 2011 | 12:31 PM
PaysonPSD's Avatar
PaysonPSD
The sending unit can get gunked up causing erratic readings. While talking with an excellent Ford mechanic he said that adding some Chevron "Pro Guard" injector cleaner has sometimes proven successful in cleaning the sender on both gassers and diesels. Certainly worth a try before dropping the tank.
I would think the use of Diesel Kleen may also clean it up and occasional use would keep it clean, let alone the benefit for the injectors.
Old Sep 5, 2011 | 12:41 PM
blue1ton's Avatar
blue1ton
My 2002 F350's fuel gauge will not read accurately between 3/4-1/2 tank. Took it in under warranty some years back but the dealer couldn't see the problem because the gauge didn't fluctaute at the time (go figure)
I would bet now if I took the truck in, the dealer would figure out the problem since it is on my dime. I have read where several of the PSD's have this issue. Seems to me Ford should correct the issues with the fuel sending units on their dime. Sounds like defective workmanship?
Old Sep 5, 2011 | 02:51 PM
slim613's Avatar
slim613
i call it a pain in the *** bobbly fuel gauge i have the same problem best way iv noticed how much fuel i have is park it running and it will tell me cuz wen i start moving i have more fuel
Old Sep 5, 2011 | 03:45 PM
Sparky0486's Avatar
Sparky0486
I have a 1/2 to 3/4 of a tank of diesel fuel. and it fluxuates up and down so I know i have enuff fuel. just want to know whats causign it.
Old Sep 5, 2011 | 04:09 PM
Franko72's Avatar
Franko72
Molon Labe
Mine will go down to 3/4's then back to full until i'm just under 1/2 tank.
At least it works on the bottom half.
I reset the trip odometer just incase the gauge quits working.
Old Sep 5, 2011 | 06:23 PM
slim613's Avatar
slim613
im doing the exact thing
Old Sep 5, 2011 | 06:35 PM
danskool's Avatar
danskool
Go Bills !
Same experience here also, Dads was stuck on full starting in May. We were just about to pull the tank a couple weeks ago before he heads back to Florida and it started working again.. He has been using his Trip all summer. He don't want to worry about it. If it does it again we will pull the tank next summer. I figure Gunk Build up.. I will let him know about Diesel Kleen trick.
king_triton
2004 - 2008 F150
Jul 21, 2013 04:53 PM
jrwendell
6.7L Power Stroke Diesel
Jun 14, 2011 07:01 AM
edub32
Aug 22, 2009 10:09 AM
rustydailey
Jun 11, 2007 04:41 PM
BigRed24
1978 - 1996 Big Bronco
13
Nov 11, 2004 12:25 AM
