AGM BATTERY
Old Feb 3, 2021 | 06:43 PM
KPFlyz's Avatar
KPFlyz
AGM BATTERY
Does anyone know how to tell a 2017-2019 F350 that it now has new AGM batteries instead of lead acid??
I bought a pair of Northstar AGM and in the specifications it says reprogramming is required.
Apparently there is something that needs to be changed. In the BCM via FORScan?? Some other way?? Other than going to dealer?
I could not find this discussed on here. I did find a youtube that discussed the importance of resetting the battery monitor system when a battery is changed to relearn how the alternator charges the battery.
Old Feb 3, 2021 | 06:52 PM
GABAR's Avatar
GABAR
There’s much debate on this matter but I changed the battery on my 2016 F150 last year because the stock battery died and my vehicle has been running fine and I didn’t reset the BCM and yes, they were AGM batteries.
On top of the battery, it should say AGM.
Old Feb 3, 2021 | 06:56 PM
Martin6's Avatar
Martin6
I didn't perform any reprogramming after I installed two new Northstar AGM batteries in my 2017 F250. No CEL or drivability issues whatsoever.
Old Feb 3, 2021 | 07:16 PM
KPFlyz's Avatar
KPFlyz
I just would like to make sure these expensive batteries last as long as possible!!
Old Feb 3, 2021 | 10:11 PM
mhoefer's Avatar
mhoefer
The programming is to tell the truck to register the new batteries. It’s not a programming thing that I am aware of. You could check with your dealer to be sure, ask the master diesel tech. I put new batteries in my 2017 this summer on the side of the road. No issues since. But they were not AGMs. It might be there is programming for the alternators though because chargers usually have electronic control with icy is different for deep cycle, lead acid and AGM. I believe the alternators are controlled to only charge at up to 14.4 volts, which is good for both lead acid flooded and AGM.
Old Feb 3, 2021 | 10:17 PM
ford390gashog's Avatar
ford390gashog
Yes you can change the BCM in the plain English setting, select AGM instead of lead acid. I did it and haven't seen any difference in charging.
Old Feb 3, 2021 | 10:40 PM
mhoefer's Avatar
mhoefer
Using Forscan Ford390
Old Feb 3, 2021 | 10:58 PM
Adam R's Avatar
Adam R
I'm not familiar with the Northstar line, but I've been running East Penn Deka AGM's in all of my vehicles for the past 15 years. They run about $150-180 each, but I get 7-9 years out of them and several vehicles have seen extensive winching duty and/or are diesels as well.
I'll have to compare the specs between Northstar and Deka, but the Deka's might be a viable option for our Ford's as well.
Old Feb 3, 2021 | 11:03 PM
ford390gashog
Yes using forscan.
Old Feb 4, 2021 | 05:49 AM
KPFlyz's Avatar
KPFlyz
Thanks for the opinions and confirming FORScan can adjust to AGM. I didn't see it on the spreadsheet which has been a valuable source of information on this site.
I'll see if I can figure that out
Thanks
Old Feb 4, 2021 | 08:59 AM
speakerfritz's Avatar
speakerfritz
we are talking differences in charge voltage and the relation ship between charge durations.
AGMs like to charge 14.6 - 14.8 and trickle at 13.6 - 13.8
lead acid like to charge at 13.8 - 14.4 and trickle at 12.9 - 13.8
most modern trucks charge at 14 - 14.5 V in SMART mode and 13.75 in dumb mode
long drives not a problem, lots of short drives with lots of restarts over a period of time could prevent the AGM from staying and higher % charge rates. this is the kind of thing that is not impossible...but difficult to do on purpose.
to test....replicate the senerios...then pull the battery and let sit over night on an insulated bench...then compare the voltage to a state of charge chart.
SBV45
2009 - 2014 F150
Jan 6, 2022 06:36 PM
JoePa2
2009 - 2014 F150
Nov 4, 2020 08:48 AM
aviatorcal
Feb 23, 2013 09:16 AM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
slifer
May 16, 2004 04:44 PM
