Charging Battery
Old Jan 25, 2020 | 05:53 PM
JoePa2's Avatar
JoePa2
Charging Battery
If you need to charge the battery in your vehicle do you take the battery leads off the battery before charging it or do you leave the cables attached to the battery - if you take them off - why? thanks
Old Jan 25, 2020 | 06:18 PM
seville009's Avatar
seville009
You can leave them on, but my preference is to completely disconnect it just to be sure nothing happens - power surge or something. Better safe than sorry.
if you’re talking about a trickle charger, definitely leave the cables on.
Old Jan 25, 2020 | 10:41 PM
steve(ill)'s Avatar
steve(ill)
you leave the cables on the battery... some newer trucks have a battery monitor system so to get around it you need to put the minus charger clamp on an aluminum or steel motor bracket, etc so the charge will go thru the system and not just the battery.. If you are just trickle charging to maintain, that is not necessary.
Old Jan 26, 2020 | 09:49 AM
gDMJoe's Avatar
gDMJoe
Exclamation
Also (since no vehicle information was provided) ... If the F-150 is 2011+
Don't forget to follow the instructions in the owner's manual regarding changing and/or the battery and the need to rest the BMS (Battery Management System).
Maintence » CHANGING THE VEHICLE BATTERY » Battery Management System ...After battery replacement, or in some cases after charging the battery with the external charger, the BMS requires eight hours of vehicle sleep time (key off with doors closed) to relearn the new battery state of charge. Prior to relearning the state of charge, the BMS may disable electrical features (to protect the battery) earlier than normal.*NOTE: FoMoCo dealership service can reset the BMS using their IDS (Intergrated Diagnostic System) negating the eight hours of vehicle sleep time requirement.
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
HINT/TIP: Put your -complete- vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Old Jan 27, 2020 | 10:17 AM
seventyseven250's Avatar
seventyseven250
I see people worrying about the BMS when this topic comes up, but I think MOST trucks see that uninterrupted 8 hours of sleep time at a few nights a week, so the truck will relearn soon enough.
If OP is talking about afully discharged, frozen or damaged battery, I'd take it inside, let it warm up for several hours before charging it. But for low-amperage maintenance charging, leave it in the truck and don't stress about it.
Old Jan 27, 2020 | 08:50 PM
steve(ill)'s Avatar
steve(ill)
I would agree... If I need a trickle charge from truck setting a few weeks, I just put it directly on the battery.. I changed out the battery on my 2013 4 times last month ( testing other vehicles) and never thought twice about it.
Old Jan 28, 2020 | 11:56 AM
JoePa2's Avatar
JoePa2
Thanks guys for the comments -
Old Nov 4, 2020 | 08:48 AM
79F150400M's Avatar
79F150400M
Delete... accidentally responded to an old thread. I try to stay relevant. Cheers!
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
HILLBILLY BOB
Oct 27, 2018 10:10 PM
john fin
Nov 24, 2011 06:11 PM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
