Just some friendly advice for you tinkering with seat mounting.
Because a seat PROPERLY mounted is vital to occupant safety using materials NOT suited for the purposes shown here so far you're jeopardizing the crash worthiness (such as it is) in the front seats. Keep in mind tubing or pipe nipples used along with the wrong grade fastener are not strong enough.
Its easy to wish Ford would have built vehicles to fit our bodies perfectly but they didn't. Some modification to the front seat belt restraint system can be done with only a minor reduction in occupant safety but the word PROPERLY figures highly into that big "if". What we've seen so far is NOT something I'd want to stake my safety on. Not being a bit facetious but that "add a cushion" idea is the best suggestion so far.
Thank you JWA for that reminder. I agree completely - one should never "shade tree" alter any safety-related device. That's just foolish.
In this case, the idea would be to raise the seat itself, not the seat base. I believe (need to check this) that the safety belts are anchored to the base, so that whole assembly is left untouched.
.... What we've seen so far is NOT something I'd want to stake my safety on. Not being a bit facetious but that "add a cushion" idea is the best suggestion so far.
So noted; however,the tensile strength of a grade8 3/8' bolt is 150,000 pounds per square inch. Square tube tensile strength of at least 42,000 psi, yield strength of at least 35,000 psi and ultimate shear strength of 27,000 psi. Therefore that modification would be the least of my worries if involved in an accident.
My concern would not be with it holding, but with insurance coverage. After an accident, if they found the seat mount altered, I can just see the insurance companies using that as an excuse to wiggle out of paying. On the other hand, people remove and install non-OEM seats in their vehicles all the time, so I don't know if this problem ever actually comes up.
One could use a quick and dirty paper based calculation or FEA software for these adapters.
Basically all you need to do is to check if the required forces and momentums from the FMVSS207 see https://www.law.cornell.edu/cfr/text/49/571.207
routed through the specific parts you use create tensions (bending and twisting) are lower than the permissible strength (or yield ) of the hardware.
I am a mechanical engineer and might be able to create a quick analysis next week.
Thank you for that, appreciated. In an accident, it's the seat belts, not the seat bottom, that are protecting the occupant. As I noted above, -> I think<- the seat belt attachment is connected to the rest of the structure through the seat base and this is not being altered in any way. If one were to change out the bolts connecting the base to the floor, the strength of the restraint system might be compromised. But in this case, those bolts are not tampered with.
Haha, I don't have your traditional seating, I have a 6 way power seat base to raise me up so I can get back in my chair, I always use grade 8 bolts and/or a large washer,steel plate on the other side to insure it doesn't pull through, tho in an accident, I have seen it tear a seat out that I had bolted down with extra support that was far more durable than factory, SOB hit me in the back shattering my spine, so much for bracing it all.
